tutorials:asterisk
Asterisk
when setting up your asterisk box you will generally be modifying two files your extensions.conf and your sip.conf or iax.conf. before beginning I think its important to note that I am not a expert at anything.. especially asterisk.. and everything I have learned has come to me on spirit quests(google). so if you see a error or you know a better way please correct me
extensions.conf
this is where your dial plan goes. or how you want your phone server to function when receiving/making calls..
For Example:
call comes in > dial your extension > dial your cellphone > forward to answering machine
call comes in > compares against blacklist > realizes its a telemarketer > forwards to sounds of creatures screaming
call comes in > asks user for extension(service, support, sales) > forwards to appropriate extension
Other things that Extensions handle
  • voicemail
  • music on hold
  • call forwarding
  • cid lookups
  • cid spoofing
  • system calls
  • sip to sip calling
  • etc etc.. skys the limit
sip.conf/iax.conf
This is where your protocol/login settings go. This is where you add information to connect to your sip or iax exchange. This is also where you will add users so they can use sip/iax extensions (soft phones, and hardware sip/iax phones).
so lets hack.
tutorials/asterisk.txt · Last modified: 2015/12/12 14:31 by 127.0.0.1
