Tidy Space Policy
Be Excellent
- Please don't strip parts from things that might be useful.
- If you want to strip a thing, please make sure to properly dispose of the rest.
Tidy Space Policy
This policy is based on the Tidy Space Policy as implemented by Pumping Station One (Chicago). The Tidy Space Policy is designed to make the “space” in “hackerspace” easier for everyone to use. It introduces a visual system of marking and tagging to indicate when something is out of place, and gives people tools to help keep things orderly. It relies on participation from every member, but is administered by Tidy Space Committee members and officers. It is, of course, to be executed alongside the Vancouver Hackspace Society Code of Conduct and the overarching rule: “be excellent to each other.”
Parking Permit
What it is
This tag should be placed on any item, project or materials used for personal or group projects, which are too large to store in personal locker or shelf space. Items with a properly issued parking permit must not be left on a Worktable or in a Walkway. Permits expire after 30 days, or on the date selected by the issuer, whichever comes first.
Who can issue
Parking permits may be issued or renewed by any officer, director, or Tidy Space Committee member, but renewals can be overruled by a majority vote of the same. Permit renewals follow the same process as new permits. The individual responsible for the material should be notified immediately of the date of issue so they can honor the term of the permit.
What’s on the form
The tag includes a brief description of the material covered, the maximum square footage taken up by the material, the name and contact information of the individual responsible for the material, the date the permit expires and the name and signature of the issuer.
Parking Ticket
What it is
This tag should be placed on any item, project or materials found in the space without an owner or any indication how long it will be there or who owns it, or if the material is obstructing a walkway, common work areas or work surfaces, or is otherwise stored in a manner that is dangerous to the material or individuals passing by.
Who can issue
Parking tickets may be issued by any officer, director, or Tidy Space Committee members.
What’s on the form
The tag includes space for a brief description of the material in question, instructions for the owner of the item, the name of the individual issuing the ticket, and the date of issue.
What happens to ticketed items
The ticket can be struck by the issue of a valid parking permit, or in the case of space property, proper labeling and storage. Ticketed material may be moved out of the way or placed in a Wut Zone, but must not be moved to Limbo until the 72 hours after the ticket is issued. The issuer, and/or Tidy Space Committee member(s), accepts the obligation to make a good-faith effort to contact the person responsible for the material (if known) to let them know their material should be retrieved or marked with a valid parking permit. If the owner is legitimately unavailable to take care of their materials within the 72 hours, the issuer and/or Tidy Space Committee members may make arrangements with the owner at their discretion.
Parking Request
What it is
This tag should be placed on any item or group of items that looks like it might be in need of either a parking permit or parking ticket. These exist so that any member can flag items needing permits/tickets and bring them to the attention of Tidy Space Committee members. A web form will be created for notifying Tidy Space Committee members of parking requests. Requests for a parking ticket may be removed by the owner of the items if the items are moved into personal storage or removed from the space.
Who can issue
Requests can be issued by any member.
What’s on the form
The tag includes space for a brief description of the material in question, check boxes to indicate the nature of the request (ticket or permit), the name of the individual issuing the request, and the date of issue.
Limbo
What it is
Limbo is a clearly marked and well lit set of shelves dedicated to almost-trash. Everything brought into limbo is marked with a date. Date marking apparatus is attached to the shelf. Anyone may remove anything from Limbo at any time. Tidy Space Committee members will periodically clear out the oldest items. If an item is too big to fit in Limbo, it is subject to disassembly or ejection from the space. In this case, if the owner is known, they shall be given two weeks to arrange for removal of the item from the space.
What can be put in Limbo and who can put it there?
- Tidy Space Committee members: Items with valid parking tickets issued more than 72 hours in the past
- Tidy Space Committee members: Items that have been in the lost and found for more than a month
- All members: Items you own
Limbo rules:
- Do not bring items to VHS specifically to put in Limbo. [note: we need a space for incoming donations and a digital form for offering donations]
- Items in the Limbo MUST be dated so that old items can be cleaned out
- If an item is of a known level of brokenness, label as such
- Items must fit on the shelves. You can make room by (re)moving or disassembling other items
- Anyone may remove anything from Limbo at any time
- If you take something out of Limbo for personal use, it must be stored properly
Wut Zones
What what they are
Each hosted area has a Wut Zone, a marked space designated for items in need of a home. The Tidy Space Committee members will sort through these areas as often as they’re able, but other members can also help.
What to put in a Wut Zone
- Things that probably belong somewhere nearby (have a look around first)
- Things that aren’t obviously useful, but aren’t obviously trash
- Things that bear no indication of where they belong
What happens to things in Wut Zones
Things found in Wut Zones will be sorted by anyone. If you encounter a populated Wut Zone, do this:
- Put the item where it belongs (if you definitely know where it goes)
- Designate a new home with a labeled bin, shelf, pegboard outline, or similar (let the Tidy Space Committee members know, chances are they’ll appreciate it)
- Take item to lost and found
- Only Tidy Space Committee members are allowed to
- Issue parking tickets
- Throw items away
- Take items to Limbo
Lost and Found
Small personal items (cell phones, wallets, multitools, hats, etc.) should be placed in the Lost and Found.
- Label found items with date and location found
- Items must remain in Lost and Found for a minimum of one month before they are moved to Limbo
- Try to inform the owner
- Communicate privately if possible
- Post to the Talk when the owner is unknown
- Include “[found]” in the subject line
Because the TidySpace policy relies heavily on Tidy Space Committee member intervention, it also requires that areas be visually well-defined, that Tidy Space Committee members are easy to contact, and that they’re able to recruit help and delegate administrative tasks as necessary.
Every square foot in the space falls under the purview of Tidy Space Committee members. In each area, the following information should be clearly visible:
- name of the area
- name and contact information the responsible members
Tidy Space Committee members may, at their discretion, recruit other members to help them manage parking requests, parking permits, parking tickets, Worktables, Walkways, and Wut Zones. Tidy Space Committee helpers agree to communicate all administrative activities to the Tidy Space Committee members. Tidy Space Committee members may revoke administrative permissions at any time, but should avoid this by selecting their helpers carefully.
Worktables
A Worktable is a surface to be used only for projects being worked on right now. Tidy Space Committee members designate Worktables in their area at their discretion. Worktables are marked either with spray paint (using a stencil like this one) or with other markings devised by the Tidy Space Committee members. Worktables must never be used to store projects not being worked on right now.
Walkways
Walkways are specially marked areas which are kept free of obstructions so that individuals may pass through them unhindered. Tidy Space Committee members designate walkways in their area at their discretion. Adherence to ADA width requirements is strongly encouraged where possible.
Designating “walkways” is an excellent way for Tidy Space Committee members to keep floorspace clear and are recommended for areas around stationary tools, shelves, and anywhere else where obstructions are unacceptable.
Although some large projects may inevitably encroach on a walkway while they’re being worked on, this should be kept to an absolute minimum. Materials should never be left in a walkway.
Standing Projects
If you need to leave a project for a short time (less than 24 hours), you are expected to put a note on your project. If other members encounter your project while you're out, the note will communicate to other members how long the project has been there, how soon they can its owner will be back to take care of it, and how to contact its owner in case it needs to be moved. “Standing Project” forms will be available but other media may be used.
Standing projects should be tagged by their owner with the following
- name & contact information
- date & time the items are being left
- justification (examples: “wet paint”, “home depot run”, “dinner”)
- when you intend to retrieve the items
Make sure your tag is visible, legible, and securely attached to your items. As a courtesy to others, and for the protection of your project, do not leave projects on a Worktable, in a Walkway, or anywhere it will be in other people's way. Projects left in people's way may be respectfully moved.
Standing projects with notes over 24 hours old are automatically subject to ticketing. Projects with notes past their stated time of retrieval are also subject to ticketing.
Moving Other People’s Projects
If you encounter what appears to be an abandoned project in a Walkway, Worktable or any place where it obstructs your activities, take a moment to assess the situation. The project’s owner might be somewhere in the building or outside. Try to find them. If they’ve left the building there should be a note nearby. After looking for a note and verifying that the person is not at the space, proceed while keeping the following in mind:
- Respecting other people's property is, of course, part of Being Excellent.
- If possible, carefully place the items in a container so that they don’t get scattered.
- Put the project somewhere nearby, such as the nearest Wut Zone.
- If items are drying, painstakingly arranged, or susceptible to damage from gentle touching, avoid moving them. If the owner is known, communicate with them.
You might feel frustrated when other people's projects are left in your way. That's understandable. But remember the rules. Be respectful and non-confrontational. Keep in mind that nobody's perfect, and that lapses in policy cannot be blamed solely on one individual. Use the opportunity to improve the space’s operation through communication.
Project and Materials Storage Limits
This section added July 2024.
- Members may store materials and projects in designated storage areas for up to 2 months. They must be clearly labeled with a Talk/Slack username, and a date including the year. Members are welcome to relabel with a new date from time to time, to extend the storage indefinitely.
- If something is found that is past 2 months, people are encouraged to contact the owner to remind them to take it away from VHS, or relabel it with a current date.
- If something is found that is past 6 months, people are encouraged to deal with it as they see fit, including disposal, using the material for themselves, marking it free for anyone, etc. There is no expectation to contact the owner prior to doing this.
- If something is found that is unlabeled, people are encouraged to label it with the current date and post on Talk to ask who it belongs to. If nobody comes forth with information within 2 weeks, then the poster can deal with it as they see fit.
