tools:boge_air_compressor
Boge Air Compressor
Big Ol' 7.5HP Air compressor! Arrived 2024-01-11 (partially killed in 2024-12-12)
Parts ordered from Pika Pumps in North Vancouver.
OIL CHANGE SHOULD BE DONE BY DEC 2025. Suction filter cleaned monthly. Section 5.3 of manual page 44.*
| Make & Model | Boge CL 7.5 |
| Year of Construction | 2012 (acquired by VHS from UBC in 2023) |
| Serial Number | 5954443 |
| CFM | 30 |
| Maximum Service Pressure | 115 PSIG |
| Motor Speed | 3600 RPM |
| Motor Power | 7.5 HP (5.5kW) |
| User Manual (compressor) | Boge Air Compressor Manual |
| User Manual (controller) | Boge Focus compressor control manual |
| Status | Operational as of Nov 2024 |
| Training | RTFM |
| Hackable | NO (Please get consensus from all members before modifying, because this compressor provides compressed air for many different areas within the space!) |
| Owner | VHS |
| If it Breaks | (Panic procedure, usually involving emailing list and “broken” sign) |
| Loan Status | (Unknown, Owned, Permanent, Temporary, Semi-Permanent |
| Arrival Date | Date (Donated by UBC) |
| Location | Compressor head is in the compressor closet, receiver (tank) is under the laser cutter bench. |
| Value | $$ |
| Champion | none yet. @androidLX, @JohnC, or @fish are probably the most knowledgeable so far |
This should outline safety concerns and guidelines for the tool and its operation.
Any maintenance, repairs, relocations, changes, etc. to the tool should be logged below with a note, date and who!
| type | Note | Date | Who |
| maintenance | The oil thermal valve purred its last, so it was replaced along with a full oil change: oil filter, oil-air separator, air filter, scavenge line filter/cap replaced, and 2 gallons of S9000 Boge oil to keep the compressor purring smoothly. | 2024-12-12 | kittycat |
| repair | A capacitor decided to nap permanently and was replaced. The motor coupler was also reseated to keep everything in pawsitive alignment. | 2024-12-12 | kittycat |
| maintenance | 5 micron filter replaced | 2024-11-12 | JohnC |
| repair | 0.3 micron filter unit bowl replaced (bowl was cracked) | 2024-11-12 | JohnC |
| Wiki entry created | 2024-07-01 | JohnC | |
tools/boge_air_compressor.txt · Last modified: 2025/01/13 02:00 by kittycat
