tools:boge_air_compressor
Boge Air Compressor
Big Ol' 7.5HP Air compressor! Arrived 2024-01-11
Make & Model | Boge CL 7.5 |
Year of Construction | 2012 (acquired by VHS from UBC in 2023) |
Serial Number | 5954443 |
CFM | 30 |
Maximum Service Pressure | 115 PSIG |
Motor Speed | 3600 RPM |
Motor Power | 7.5 HP (5.5kW) |
User Manual (compressor) | Boge Air Compressor Manual |
User Manual (controller) | Boge Focus compressor control manual |
Status | Operational as of Nov 2024 |
Training | RTFM |
Hackable | NO (Please get consensus from all members before modifying, because this compressor provides compressed air for many different areas within the space!) |
Usage Restrictions | Anyone |
Owner | VHS |
If it Breaks | (Panic procedure, usually involving emailing list and “broken” sign) |
Loan Status | (Unknown, Owned, Permanent, Temporary, Semi-Permanent |
Arrival Date | Date (Donated by UBC) |
Location | Compressor head is in the compressor closet, receiver (tank) is under the laser cutter bench. |
Value | $$ |
Champion | none yet. @androidLX, @JohnC, or @fish are probably the most knowledgeable so far |
This should outline safety concerns and guidelines for the tool and its operation.
Any maintenance, repairs, relocations, changes, etc. to the tool should be logged below with a note, date and who!
type | Note | Date | Who |
maintenance | 5 micron filter replaced | 2024-11-12 | JohnC |
repair | 0.3 micron filter unit bowl replaced (bowl was cracked) | 2024-11-12 | JohnC |
Wiki entry created | 2024-07-01 | JohnC |
tools/boge_air_compressor.txt · Last modified: 2024/11/12 22:16 by johnc
