tool:laser_cutter:maintenance_logs:2017_05_27
Written by: Jake McIvor
Laser Cutter Maintenance
Richard and I performed some preventative maintenance on the laser cutter:
  • Used windex to clean all the viewing ports
  • Vacuumed all debris out of the bed
  • Tightened up the head assembly belt and the set screws on the pulleys
  • Cleaned the ways with WD-40, then lubricated with oil
  • Oiled all bearings and bushings
  • Removed broken key from front cabinet lock
  • Cleaned mirrors and focal lens with optical wipes and alcohol
  • Aligned mirrors
tool/laser_cutter/maintenance_logs/2017_05_27.txt · Last modified: 2017/05/28 14:56 by jdmc
