tool:hp_laserjet_3600n
HP Color LaserJet 3600n
BROKEN
| Status | Broken - electronics error, feel free to fix |
| Training | Optional |
| Hackable | YES |
| Owner | VHS |
| If it Breaks | (Panic procedure, usually involving emailing list and “broken” sign) |
| Loan Status | Unknown |
| Arrival Date | Date |
| Location | 3D Printing area |
| Value | $$ |
This printer is broken and hackable if you wish
Setup: Mac OS X
- Go to System Preferences → Printers
- Click the + sign to add a printer
- Select IP
- Enter the Address: 172.16.0.8 and select the Protocal 'HP Jetdirect - Socket'
- Use should populate with 'HP Color LaserJet 3600'
- Click 'Add'
Setup: Linux (KDE)
- Control Center → Printers
- Select 'Add'
- Select 'Network Printer'
- Select 'Other'
- Name Anything you want we suggest 'VHS_Lasjer_3600n'
- Make sure 'AppSockets/HP JetDirect'; is selected
- YOU MUST MAKE SURE Driver is set to 'Foomatic + hpijs'
- For path enter
socket://172.16.0.8
- On the Printer Model Screen
- On the next screen make sure it knows the model is a 'LaserJet 3600'
- Leave the select defaults alone
- We recommend printing a test page
- Make sure to select 'Finish'
tool/hp_laserjet_3600n.txt · Last modified: 2019/04/23 21:17 by 00739
