tool:bosch_4.5_angle_grinder
Information
- Quantity = 2
- owner = Vancouver Hack Space
- user certification required = Must be or be with an experienced operator
- hackable = No (See tips below)
- model = Bosch 1375A 4-1/2“ Small Angle Grinder
- serial # =
- arrived = July 2014
- does it work? = Works
- if it breaks = Put a "broken" sign on machine, contact John.
- contact = John Craver
- where = workshop
- replacement value (each) = $80
Mandatory:
- Face Shield AND Safety Glasses
- Hearing Protection
- Leather Work Boots
- Fire Extinguisher
- A clean work area (clutter makes it hard to search for embers)
- Clamps or Bench Vise
Optional:
- Heavy leather welding gloves
- Leather apron
- Clothes made of synthetic materials (can catch on fire)
- Any gloves other than heavy leather welding gloves (can get caught
- Jewellery, Long Hair (tie back), and loose fitting clothing.
- Aluminum (Never grind aluminum, it can cause the grinding wheel to explode)
Description:
To avoid accidents, the following operational safety rules must be observed by everyone using the Vancouver Hack Space angle grinder. Failure to follow the safety rules may result in a loss of shop privileges.
- Do not use the angle grinder when there are others in the space, unless they are paying attention to your work and they are also wearing the required personal protective equipment!
- Safety glasses and a face shield MUST be worn. Hearing protection MUST be worn. Always have a fire extinguisher or bucket of water nearby when grinding.
- Remove loose fitting clothing, jewelry, and tie back long hair.
- Give the work your undivided attention.
- Always search thoroughly after grinding for any sparks which may cause flammable material to ignite.
- Approach your work at VHS and with the cordless drill with a safe attitude!
- Never use any grinding accessory larger than 4.5 inches in diameter!
- Always check that the maximum safe operating speed of the grinding accessory is greater than that of the grinder!
- Never remove guards!
- Never grind aluminum!
tool/bosch_4.5_angle_grinder.txt · Last modified: 2015/12/12 14:31 by 127.0.0.1
