tool:badge_a_minit_button_maker
Button Maker
| Status | Opperational as of April 2019 |
| Training | Recommended so you don't waste materials |
| Owner | VHS |
| If it Breaks | You'd have to make a real effort to break this. Don't drop it. |
| Loan Status | Owned |
| Arrival Date | Date |
| Location | Underneath the crafting table, side closest to couches |
| Value | $$ |
Notes about the button maker:
- It makes 1 1/2“ buttons
- There is a cutter to cut out paper circles for buttons. It should be with the button maker. It's made of metal and is pretty heavy duty, about 5” square base, with a little handle to pull down and punch the circles out.
Template
Template for designing your button button_template_markup.pdf
Supplies
Button maker and button supplies are located under the craft table, near the couches. Locally Blim and Six Cent Press have parts.
tool/badge_a_minit_button_maker.txt · Last modified: 2019/04/23 01:36 by dbynoe
