tool:air_compressor
Air Compressor
| Make & Model | Campbell Hausfeld VT627505AJ |
| Serial Number | L12/18/07-00082 |
| User Manual | vt6275_manual.pdf |
| Status | Operational as of 2021-04-21 |
| Training | RTFM |
| Owner | VHS |
| If it Breaks | Post on Talk, tape an Out of Order sign onto it |
| Arrival Date | Date |
| Location | Woodshop soundproof closet |
| Value | $$ |
Oil type: SAE30 Air Compressor Oil, or 10W30 Full Synthetic motor oil
Specs: 60 Gallon 135 PSI Max. 3.2 HP Motor 240V 15A 60Hz 1ph 11.5 SCFM @ 40PSI 10.2 SCFM @ 90PSI
Motor: Model: Emerson T63XWBSS1486 Definite Purpose Compressor Motor FLA: 15.0 RPM: 3450 Frame Size: 56 Insulation Type: T Duty: Continuous Locked Rotor Amps: 93
| Note | Date | Who |
| Wiki entry created | 2021-04-21 | John C. |
| Oil changed | 2021-04-21 | John C. |
tool/air_compressor.txt · Last modified: 2021/04/30 03:06 by johnc
