Lightobject Q800 Water Chiller
VHS has purchased a Lightobject Q800 Water Chiller to cool its laser tube.
LightObject’s Q800 Water Chiller offers exceptional performance, consistency, and reliability thanks to the high quality JLD612 PID-controller and our two-stage compressor system. This unit features an oversized capacitor which alleviates issues with circuit over-drawing during starting amperage that are common in other chillers.
The JD612 PID controller is capable of achieving a 0.1°C setpoint resolution and features a dual-display that shows both the setpoint and the current system temperature. The compressor utilizes an environmentally-friendly refrigerant, R134a.
The internal pump is rated for 10 meters of lift at a flowrate of 19 Liters/min to ensure adequate circulation of coolant regardless of chiller placement. The unit is suitable for ambient conditions up to 35°C, with a selectable cooling range of 18°C - 30°C.
Highlight
- 20% cooling performance improvement
- Integrated temperature controller installed
- Better temperature control +/- 0.5'C
- Ideal for a machine with a single 80W~130W tube
Features
- Environment-friendly refrigerant R134a
- PID temperature controller
- Compact design
- Over-heat temperature and water flow alert
Specification
- Cooling Power: 800W
- BTU: 2,729Btu/h
- Power consumption: 370W
- Input power: AC 110V, 60Hz
- Full power current: 3.5A
- Refrigerant: R134A
- Pump power: 30W
- Pump lift (cut off) : 10m (33ft)
- Pump flow rate: 19L/min, 300GPH
- Suggested Inlet/Outlet tubing: 8mmx12mm Silicone Tubing
- Silicone tubing included: No
- Ambient Temp: ≤35°C (95°F)
- Chilled Water Temp. 18~30°C(64.4~86°F)
- Water tank capacity: 7L
- Weight: 24kg (52lb)
- Dimensions: W405×D470×H480mm (16“ x 18.5” x 19“) note: depth measured from blue cap
- Warranty - 12-month limited warranty from date of purchase.
- Purchased July 14th 2022, Order No 2158754 by Arrgh (Alex C) $595US Total incl shipping.
Photos
Instructions
