tool:lightobject_q800_water_chiller
Lightobject Q800 Water Chiller
VHS has purchased a Lightobject Q800 Water Chiller to cool its laser tube.
LightObject’s Q800 Water Chiller offers exceptional performance, consistency, and reliability thanks to the high quality JLD612 PID-controller and our two-stage compressor system. This unit features an oversized capacitor which alleviates issues with circuit over-drawing during starting amperage that are common in other chillers.
The JD612 PID controller is capable of achieving a 0.1°C setpoint resolution and features a dual-display that shows both the setpoint and the current system temperature. The compressor utilizes an environmentally-friendly refrigerant, R134a.
The internal pump is rated for 10 meters of lift at a flowrate of 19 Liters/min to ensure adequate circulation of coolant regardless of chiller placement. The unit is suitable for ambient conditions up to 35°C, with a selectable cooling range of 18°C - 30°C.
Highlight
  • 20% cooling performance improvement
  • Integrated temperature controller installed
  • Better temperature control +/- 0.5'C
  • Ideal for a machine with a single 80W~130W tube
Features
  • Environment-friendly refrigerant R134a
  • PID temperature controller
  • Compact design
  • Over-heat temperature and water flow alert
Specification
  • Cooling Power: 800W
  • BTU: 2,729Btu/h
  • Power consumption: 370W
  • Input power: AC 110V, 60Hz
  • Full power current: 3.5A
  • Refrigerant: R134A
  • Pump power: 30W
  • Pump lift (cut off) : 10m (33ft)
  • Pump flow rate: 19L/min, 300GPH
  • Suggested Inlet/Outlet tubing: 8mmx12mm Silicone Tubing
  • Silicone tubing included: No
  • Ambient Temp: ≤35°C (95°F)
  • Chilled Water Temp. 18~30°C(64.4~86°F)
  • Water tank capacity: 7L
  • Weight: 24kg (52lb)
  • Dimensions: W405×D470×H480mm (16“ x 18.5” x 19“) note: depth measured from blue cap
  • Warranty - 12-month limited warranty from date of purchase.
  • Purchased July 14th 2022, Order No 2158754 by Arrgh (Alex C) $595US Total incl shipping.
Photos
Instructions
tool/lightobject_q800_water_chiller.txt · Last modified: 2022/07/19 22:40 by majicj
