tool:laser_cutter:maintenance_logs:2017_05_27
Written by: Jake McIvor
Laser Cutter Maintenance
Richard and I performed some preventative maintenance on the laser cutter:
- Used windex to clean all the viewing ports
- Vacuumed all debris out of the bed
- Tightened up the head assembly belt and the set screws on the pulleys
- Cleaned the ways with WD-40, then lubricated with oil
- Oiled all bearings and bushings
- Removed broken key from front cabinet lock
- Cleaned mirrors and focal lens with optical wipes and alcohol
- Aligned mirrors
tool/laser_cutter/maintenance_logs/2017_05_27.txt · Last modified: 2017/05/28 14:56 by jdmc
