tool:barry_the_14_bandsaw
Barry the 14" Wood Bandsaw
Barry has gone home, so long and thanks for all the chips.
Barry is a General International model #90-125 14“ wood bandsaw. He is owned by @dbynoe, and is on long term loan to the space, so please treat the bandsaw nicely.
Status | Removed from space April 2024 |
Training | If required |
Hackable | NO |
Usage Restrictions | Members Only - for cutting wood only, NO CUTTING OF: fiberglass, metal, fingers, meat, soft melty plastics, vegetables, drywall, concrete, stone, etc. - Foam can be cut but the machine must be cleaned after use, and the blade replaced at the users cost as it will get dull fast |
Owner | @dbynoe |
If it Breaks | Unplug machine, put a “broken” sign on machine, contact @dbynoe |
Loan Status | Long term |
Arrival Date | October 2019 |
Location | Woodshop |
Value | $700 |
Blade Length | 93.5” max width of 1/2“ |
- Safety Glasses
- an experienced bandsaw operator (if this is not you, you must get someone to help you!)
- Hearing Protection
- Dust protection
- Loose clothing
- Loose hair
- Cutting of materials other than wood.
Safe Operation Details
See the manual for instructions on changing the blade, including proper tensioning and setting up the guides: Bandsaw Manual
tool/barry_the_14_bandsaw.txt · Last modified: 2024/04/29 05:25 by dbynoe
