hacks:fpga:zedboardjtag
Instructions to install Zedboard JTAG drivers in Linux
- Plug in the Jtag USB beside the power connector and the UART USB on the otherside of the power connector.
- JP7 - JP11 should be “down” connecting SIG to GND.
- Power on the Zedboard and you should see to USB devices connected.
- lsusb
- Future Technology Devices
- Cypress Semiconductor Corp.
- Install the JTAG drivers
- select Digilent ADEPT, select Download
- Download and install Runtime and Utilities
- select Digilent Plugin for Xilinx Tools, Select Download
- Download the libCseDigilent plugin tar file.
- copy Digilent plugin files
- from libCseDigilent_2.5.2-x86_64/ISE14x/plugin
- to SDK/2015.1/lib/lnx64.o
- to Vivado/2015.1/data/xicom/vcse_plugins/lnx64.g/Xilinx/libCseTcfPlugin
- sudo udevadm control -R
- djtgcfg enum “if this detects the Digilent Zed” the reboot is optional
- reboot after
- djtgcfg enum “should find Digilent Zed”
hacks/fpga/zedboardjtag.txt · Last modified: 2017/03/31 19:19 by tdwebste
