hacks:fpga:parallellaopencl
Hi Tim, Following are my notes from the Saturday (March 25th, 2017) class: Thanks, Rahul Install COPRTHR SDK PARALLELLA PAGE: https://www.parallella.org/2013/03/08/introduction-to-parallella-and-opencl/ http://www.browndeertechnology.com/coprthr_download.htm GITHUB PAGE: https://github.com/browndeer/coprthr (Procedure Explained) sudo apt-get install gmake apt-get install freebsd-glue sudo aptitude install bison sudo apt-get install flex gitclone libelf Installation is straightforward - the package is autoconf'ed. Just do cd libelf-0.8.13; ./configure; make; (sudo) make install''. Header files will be installed in .../include/libelf/. libconfig ./configure make sudo make install sudo aptitude install autogen The following NEW packages will be installed: autogen autogen-doc{a} libopts25{a} libopts25-dev{a} 0 packages upgraded, 4 newly installed, 0 to remove and 0 not upgraded. Need to get 1,714 kB of archives. After unpacking 5,179 kB will be used. Do you want to continue? [Y/n/?] Y autogen ./configure && make DOWNLOAD libevent-2.0.18/ OR GIT CLONE libevent-2.0.21-stable {ls -al} {head autogen.sh} bash autogen.sh ls -alrt date ./configure ls -lart make sudo make install make verify cd coprthr ./configure make ls -alrt make clean sudo make install
hacks/fpga/parallellaopencl.txt · Last modified: 2017/03/28 07:01 by tdwebste
