Status Being tested.
  • Software: Runs UCCNC
  • Horsepower: TBD
Backlash
Raw mechanical backlash before compensation: X: 0.08mm, Y: 0.06mm, Z: 0.16mm (Z does not have an encoder!).
Rigidity
To be measured…
  • Y: 130-180mm, depending on workholding.
See the Jaxen operating guide for details.
Maintenance
For regular maintenance, see the Jaxen Operating guide. The following are maintenance projects that are identified to be beneficial in machine performance.
ToDo List
  • basic door on front
  • Add encoder to Z axis, change driver to A spare or get new driver that supports encoder feedback. Impact: there is currently odd behaviour in the Z-axis, which may impact it's accuracy. It's not known for sure whether this is related to lack of encoder.
  • Measure rigidity
  • Coolant system
2026 Aug 28 Colin L Splice spindle encoder cable, terminate, cable management, encoder PPM settings adjust.
  • Arrival location: Workshop
  • Came with R8 tooling
wiki/tools/jaxen_cnc_mill.1789772304.txt.gz · Last modified: 2026/09/18 15:58
