- keeping users safe
- Workpiece holding
- Startup procedure
- G-Code Workspaces
- Sign up for Jaxen training here using this google form submission
- On your training day 1:
- Do the exam verbally at the end of this page.
- You pass with 10/12 correct answers.
- Training Day 2:
- Your name is added to the list of trained people TODO where will this be???
- Your first personal project:
- For your first project, you must discuss your project plan with a CNC committee member who is currently offering training. This is to help you apply the skills you learned from the training to new scenarios. Also, experienced members can help you get what you want: either fast production, or high quality. Be sure to tell them what you want.
- Your 2nd and later projects:
- On your second and later projects, you are encouraged to ask for advice, but you can begin using the machine without the need for permission, while still minding other's access to the machine. By then, you'll have enough experience, you'll probably be teaching us!
- Sign in on the log book before you start working!
- Listen to the sound of the mill. Squealing means that something is vibrating, and will negatively impact your finish or part tolerances.
- If you're a committee member and modifying the machine, check and update Jaxen's homepage!
- Wipe the vice before clamping. Chips between metal cause dimension errors.
- Tap the workpiece into the vice- must be resting on parallels- this eliminates “vice-lift” (Jaxen's vice is pretty resistant to this, but it's still good practice).
- Sign in by writing your name and date on the paper log. This is so you can see what else is happening with this shared machine.
- Boot the PC
- Login to the PC
- Home the machine
- Shutdown PC
- Power off the CNC (unplug)
Jaxen is really just a manual mill with electrical controls added. Here's some important specs that are mostly characteristic of the Grizzly mill:
- Repeatability: 0.005mm (aka Precision. This is the typical error you'll see when homing)
- Rigidity: ideally 0.01mm in X and Y. (Accuracy of tool to workpiece). Note that this is ideal conditions, and doesn't consider effects of ineffective tool bite. Z axis is also undefined accuracy since there is no closed loop feedback. In practice, it has not been noticeable. If you want dimensional accuracy greater than 0.1mm, it takes lots of careful checking and measurement.
Most mill skills won't be covered in this guide, but here's some important ones relevant for Jaxen specifically:
Squaring Stock
Facing/Surfacing
- Vice bolted to the table
- Your part does not have at least 2 parallel faces that are rigid enough to be load bearing.
Tool Bit Examples
- End mill
- Chamfer/bevel
- Ball mill
- Arbour/Shell mill
There are infinite toolholding methods out there, but this table is handy so you know what's in the CNC cabinet!
TODO make into table
- Aluminum: WD40 (optional)
- Steel: Tap Magic
- Stainless-Steel: Anchorlube Metalworking Compound (not yet tested on Jaxen)
Material Tips:
Maintenance involves:
- Maintaining the core Grizzly Milling Machine. Refer to the original manual on lubrication practices.
- Checking that limit switch brackets are tight and homing correctly (there are 3 brackets).
- Watching for stepper driver overload faults (axis stops moving until power cycle).
- Listening for noisy fans clogged with dust.
- Updating Windows on the computer, and FreeCAD.
General Maintenance Tips:
For lubricating gears or parts that have high forces between them (normal to the surface that the grease is on, not sliding across): use High-pressure grease. Blondiehacks recommends: MAG1 High Temp Disc Brake Wheel Bearing Grease Lithium Complex https://www.youtube.com/watch?v=x8tx-cBulno
But first, what is a “Job” in Freecad?
A Job is a set of “Operations” performed on the stock material to approach the shape of your “Model”. A Job also defines the milling machine's workspace origin, and can have only one. This means that if you want to move or reorient your part between Operations, this means you need to create a new Job. In FreeCAD, you will notice that your model will appear in two different places! This is because your Body's origin will almost always be different from the the milling machine's origin. To avoid confusion, hide either your Body or the Model of your Job.
- If creating a new bit: Chipload can be left at 0mm. Tool length generally doesn't matter.
- Click “Add to Job”
Tip: Any mentions of “depth” or “height” for any operations are relative to the top surface of the stock that you've setup in FreeCAD. Be sure that this is set how you expect!
Engraving Tips
You may find more info here, but it's not super helpful: VCarve Wiki page
- Make your part/body first as normal
- Go to Draft workbench, and create a ShapeString. It won't be on the face you want, but that's OK.
- Move the ShapeString object to be on the face you want- the Z axis is what's important. One way is by using the parameters in the left panel.
- Adjust any other settings like scale and rotation.
- Return to the Part workbench.
- In the left panel, Model hierarchy, check that the ShapeString object is NOT inside any Parts or Bodys. It must be at the same level as your body (it should not disappear when you collape all Bodys. If not, Drag and drop the ShapeString object so that it becomes top-level.
- Go to the CAM workbench.
- Create a new Job, or double click an existing job to edit. (It's suggested to add to an existing to reuse your Job settings).
- In the General tab, add your shapestring object to the job: Job Edit > General > Model.
- In the popup window, make sure the shapestring object is selected. It should appear under the 2D category.
- Close the job edit task.
- You must add at least one V bit to the job's tools before adding VCarve.
- Now to add the VCarve Operation
- Select the Shapestring object inside the model parts within the Job!! NOT the shapestring object that is part of your Part Body.
- Create a new VCarve operation with the button in the toolbar. The shapestring should be added to the list of base geometry in the task editor window.
- Set the depth of the opreration to be excessively deep- it should not limit the tool depth. Depth at any given point is determined automatically.
- Ensure that step-down is set appropriately- TODO need to adjust….. recommend 0.3mm for steel, can be larger for Aluminum.
- Check the “Optimize movements” option. It will make the operation faster by taking shortcuts. It will not raise the tool in some cases, so this means that it's more critical for you to setup the Z axis precisely, to match the work surface. You must ensure that the top corners of the chamfers are above the surface being engraved.
- Click Apply button to preview the paths of the Operation, then OK when you're done.
- Double-check your feed rates and spindle RPMs for the tool controller that was used in the VCarve operation. You may want to create a new ToolController object to get custom feeds/speeds for this operation.
- Check the simulation of the Job by clicking the button in the toolbar.
- Click Post process. Your G-Code will be saved to the working directory where your FreeCAD file is saved!
- LOAD FILE in UCCNC, and see that it looks correct in the Main window.
- Proceed to the CNC setup section!
Very detailed video including modelling techniques and various CAM operations, which these steps are mostly based on:
Jaxen training demo project
- Getting good surface finish
- Verifying dimensions
- Through-hole opening
- Engraving
- Chamfer
- Work from the inside out, because the outer material is what typically touches the vice, and also the perimeter is usually more volumeous than the inner parts, so it makes the part more rigid for longer during the job.
- Do blind pockets in steps, because the deeper any single pass, the more the bit will vibrate, and this makes the walls rough.
- The final pass should always be very thin for the best finish. 0.1mm finishing pass usually works well.
- When designing your CAD, inside corner radii are limited! Keep in mind the radius of your toolbits.
- Absolute: G90
- Relative: G91
- Absolute positioning: G90
- Relative positioning: G91
- Rapid move: G0 x50
- s1000
- G54 = User defined #1
- G55 = User defined #2
- G56 = User defined #3
- G59 #6 = User defined #6
- The shape of your stock
The general steps are:
- Pick an axis to find
- Save this position:
- Repeat for the other axes.
Variations:
- Use an edge finding tool.
Practice!
- Click REWIND FILE
- Do whatever you need while the machine is paused. Move workholding/workpiece, or manually jog the machine.
- HOWEVER: be careful of executing G-Code in this state! Your program may be depending on mode G90 or G91, and any other settings, and won't know if you change them!
- What is the most important thing (that was taught to you during training) to prevent when installing/removing collets?
- What is the most important thing (that was taught to you during training) to prevent after installing/removing collets?
- What does G54 mean?
- You are planning a surfacing operation in CAM. What resources can you consult to figure out an appropriate feed rate of the tool?
