| Status | Being tested. |
- Software: Runs UCCNC
- Weight: ~200 kg
- Horsepower: TBD
Backlash
Rigidity
To be measured…
- Y: 130-180mm, depending on workholding.
Maintenance
ToDo List
- basic door on front
- tramming, squaring vice, and other mill accuracy verification procedures.
- Measure rigidity
- Add alarm monitoring of stepper drives as digital input (can monitor all in series with 1 input point)
- Coolant system
- Add 2nd solid state relay to cut off power to motor drivers.
- Check effectiveness of spindle encoder index pin, and potentially remove to free-up IO. Since it is not actually on spindle, index is not indicating any real fixed location.
| Date | Who | Note |
| 2026 Aug 28 | Colin L | Splice spindle encoder cable, terminate, cable management, encoder PPM settings adjust. |
| 2026 Aug 21 | Colin L | Ground bus bar behind controller re-soldered, fix intermittent connections (spindle grounding). Tighten limit switch bracket (Z). Added 2nd magnet to Z limit post after failed homing. Remeasured backlash, same results. Setup software backlash compensation using test results, re-tested showing accuracy is now about 0.01mm. |
| 2026 Aug 15 | Colin L | Cut another notch in rear enclosure panel for column access. |
- Arrival location: Workshop
- Came with R8 tooling
