Status Being tested.
  • Software: Runs UCCNC
  • Horsepower: TBD
Backlash
Rigidity
To be measured…
  • Y: 130-180mm, depending on workholding.
Maintenance
ToDo List
  • basic door on front
  • Add encoder to Z axis, change driver to A spare or get new driver.
  • Measure rigidity
  • Coolant system
2026 Aug 28 Colin L Splice spindle encoder cable, terminate, cable management, encoder PPM settings adjust.
  • Arrival location: Workshop
  • Came with R8 tooling
wiki/tools/jaxen_cnc_mill.1789362202.txt.gz · Last modified: 2026/09/13 22:03
