Status Being tested.
  • Software: Runs UCCNC
  • Horsepower: TBD
Rigidity + Backlash
  • Y: ~130mm, see note below.
Y axis increase plan:
Maintenance
ToDo List
  • basic door on front
  • Coolant system
2026 Aug 28 Colin L Splice spindle encoder cable, terminate, cable management, encoder PPM settings adjust.
  • Arrival location: Workshop
  • Came with R8 tooling
wiki/tools/jaxen_cnc_mill.1787990432.txt.gz · Last modified: 2026/08/29 01:00
