As of 2026 March, it is being prepared for wider member use by the Metal CNC committee.
Status Being tested.
  • Software: Runs UCCNC
  • Horsepower: TBD
Rigidity + Backlash
  • Y: ~130mm, see note below.
Y axis increase plan:
Maintenance
ToDo List
  • basic door on front
  • Coolant system
  • Arrival location: Workshop
  • Came with R8 tooling
wiki/tools/jaxen_cnc_mill.1787522041.txt.gz · Last modified: 2026/08/23 14:54
