As of 2026 March, it is being prepared for wider member use by the Metal CNC committee.
| Status | Being tested. |
- Software: Runs UCCNC
- Weight: ~200 kg
- Horsepower: TBD
Rigidity + Backlash
2026 Aug updated tests: With software backlash compensation enabled, users can expect accuracy of 0.01mm or better in X and Y.
Raw mechanical backlash before compensation:
- X: 0.08mm
- Y: 0.06mm
- Z: 0.16mm * This is being investigated further.
- Y: ~130mm, see note below.
Y axis increase plan:
Maintenance
ToDo List
- Splice spindle encoder cable (or run with PID control turned off)
- basic door on front
- tramming, squaring vice, and other mill accuracy verification procedures.
- Add alarm monitoring of stepper drives as digital input (can monitor all in series with 1 input point)
- Coolant system
- Add 2nd solid state relay to cut off power to motor drivers.
| Date | Who | Note |
| 2026 Aug 21 | Colin L | Ground bus bar behind controller re-soldered, fix intermittent connections (spindle grounding). Tighten limit switch bracket (Z). Added 2nd magnet to Z limit post after failed homing. Remeasured backlash, same results. Setup software backlash compensation using test results, re-tested showing accuracy is now about 0.01mm. |
| 2026 Aug 15 | Colin L | Cut another notch in rear enclosure panel for column access. |
Ownership History
- Arrival location: Workshop
- Came with R8 tooling
