Status Being tested.
  • Software: Runs UCCNC
  • Horsepower: TBD
Rigidity + Backlash
2026 Aug updated tests: With software backlash compensation enabled, users can expect accuracy of 0.01mm or better in X and Y.
Raw mechanical backlash before compensation:
  • X: 0.08mm
  • Y: 0.06mm
  • Z: 0.16mm * This is being investigated further.
  • Y: ~130mm, see note below.
Y axis increase plan:
Maintenance ToDo List
  • basic door on front
  • Coolant system
  • Arrival location: Workshop
  • Came with R8 tooling
wiki/tools/jaxen_cnc_mill.1787446172.txt.gz · Last modified: 2026/08/22 17:49
