Status Being tested.
  • Software: Runs UCCNC
  • Horsepower: TBD
Rigidity + Backlash
  • Y: ~130mm, see note below.
Y axis increase plan:
Maintenance ToDo List
  • basic door on front
  • Coolant system
2026 Aug 21 Colin L Ground bus bar behind controller re-soldered, fix intermittent connections (spindle grounding). Tighten limit switch bracket (Z). Remeasured backlash, same results. Setup software backlash compensation using test results, re-tested showing accuracy is now about 0.01mm.
  • Arrival location: Workshop
  • Came with R8 tooling
wiki/tools/jaxen_cnc_mill.1787444719.txt.gz · Last modified: 2026/08/22 17:25
