Status Being tested.
  • Software: Runs UCCNC
  • Horsepower: TBD
Rigidity + Backlash
  • Y: ~130mm, see note below.
Y axis increase plan:
Maintenance ToDo List
  • basic door on front
  • software backlash compensation setup using test results and then re-test.
  • Coolant system
2026 Aug 21 Colin L Ground bus bar behind controller resoldered, fix intermittent connections (spindle grounding). Tighten limit switch bracket (Z).
2026 Aug 15 Colin L Cut rear enclosure panel for future access.
  • Arrival location: Workshop
  • Came with R8 tooling
wiki/tools/jaxen_cnc_mill.1787384594.txt.gz · Last modified: 2026/08/22 00:43
