| Status | Being tested. |
- Software: Runs UCCNC
- Weight: ~200 kg
- Horsepower: TBD
Rigidity + Backlash
- Y: ~130mm, see note below.
Y axis increase plan:
Maintenance ToDo List
- Splice spindle encoder cable (or run with PID control turned off)
- basic door on front
- tramming, and other mill accuracy verification procedures.
- software backlash compensation setup using test results and then re-test.
- Coolant system
| Date | Who | Note |
| 2026 Aug 21 | Colin L | |
| 2026 Aug 15 | Colin L | Cut rear enclosure panel for future access. |
- Arrival location: Workshop
- Came with R8 tooling
