Jaxen - CNC Milling Machine
Status Being tested.
  • Software: Runs UCCNC
  • Horsepower: TBD
Rigidity + Backlash
  • Y: ~130mm, see note below.
Y axis increase plan:
Maintenance ToDo List
  • Splice spindle speed control cable
  • Splice spindle encoder cable
  • Y-axis stepper cable management
  • tramming
  • basic door
  • software backlash compensation setup using test results and then re-test.
  • Coolant
  • Need to replace the spindle DC brushed motor and drive train, with has about 10 degrees of backlash- hekseskudd says this would be the biggest single improvement to surface finish. Like the big spindle motor Gage had……….
  • Consider spare parts for the most common things users could break, like spindle system
  • Consider systems for preventing crashes.
2026 Aug - Restore Jaxen to service; in progress.
  • Arrival location: Workshop
  • Came with R8 tooling
wiki/tools/jaxen_cnc_mill.1786171766.txt.gz · Last modified: 2026/08/07 23:49
