'Jaxen' - CNC Milling Machine
Status Operational.
  • Runs UCCNC
  • Includes R8 tooling
2026 Mar + ColinL Created new profile for metric G-Code, spindle PID loop, created workholding bed, wiring cleanup, backlash benchmarking…
wiki/tools/jaxen_cnc_mill.1785227305.txt.gz · Last modified: 2026/07/28 01:28
