'Jaxen' - CNC Milling Machine
| Status | Operational. |
- Runs UCCNC
- AXBB-E (CNCdrive) controller with UCCNC. See information below
- CNC mill controller installed in Wall panel. See information below.
- Includes R8 tooling
- New Base: King Industrial base purchased
- Original Base: Wood 93 × 61 cm footprint, 93 cm tall (engine hoist fits underneath)
- Weight: ~200 kg
- Modified with CNC Fusion stepper + ballscrew kit (original parts retained)
- Mandatory training required before use
- Must first complete training and certification on the 6040 CNC Mill "Loratron"
- Certification must be recorded before using Jaxen
| Date | Who | Note |
| 2026 Mar + | ColinL | Created new profile for metric G-Code, spindle PID loop, created workholding bed, wiring cleanup, backlash benchmarking… |
- Arrival location: Workshop
- King Industrial Stand purchased for mill ~$300-$400(KMS Tools)
- Most of Tooling that came with machine seems to have gone missing:
CNC mill controller setup
1. Power Supplies
- NDR-480-48 (x2): Provide 48V, 10A DC to the stepper/servo drivers (blue modules marked Motor Z/A and Motor X/Y).
- These deliver the high-power DC that actually runs the motors.
- MDR-60-24: Provides 24V DC for control electronics (like relays, sensors, and logic boards).
- MDR-60-5: Provides 5V DC for logic-level components (controller board, encoders, or optoisolators).
Hookup:
- AC mains (100–240V) enters at the bottom (L/N/Earth).
- DC outputs (+V and –V) run to the motor drivers and controller boards.
2. Motor Drivers
- Function: Convert low-level step/direction/enable signals from the controller into high-power pulses for the motors.
- Each axis has its own driver.
- Wiring:
- Signal side (green connectors): Receives Step (Red), Dir (White), Ena (Green) from the motion controller.
- Power side: Fed by 48V from the NDR-480 supplies.
- Motor outputs: Four heavy wires going to each motor coil.
- Rotary encoder inputs: see Motor (XY) Rotary Encoder Pinouts below
| Pin # | Pin Label | Description | Encoder Wire Color |
| 1 | EB+ | Encoder B phase input + | Yellow |
| 2 | EB- | Encoder B phase input - | Green |
| 3 | EA+ | Encoder A phase input + | Black |
| 4 | EA- | Encoder A phase input - | Blue |
| 5 | VCC | Encoder voltage (+5V) | Red |
| 6 | EGND | Encoder ground (0V) | White |
| Pin # | Signal | Function | “Standard” Color (from prior table) | Jaxen Cable Color |
| 1 | EB+ | Encoder B phase input + | Yellow | Green |
| 2 | EB- | Encoder B phase input - | Green | Black (label: EB−) |
| 3 | EA+ | Encoder A phase input + | Black | White |
| 4 | EA- | Encoder A phase input - | Blue | Black (label: EA−) |
| 5 | VCC | Encoder supply +5 V | Red | Red |
| 6 | EGND | Encoder ground (0 V) | White | Black (label: GND) |
HSS57 Hybrid Servo Driver
Device Identification
- Model: HSS57
- Type: Hybrid Servo Driver (closed-loop stepper controller)
- Voltage Range: 24–50 VDC
- Control Interface: Step/Dir inputs
- Feedback: Encoder input (closed-loop control)
Connections
Motor (4 terminals)
- A+, A–
- B+, B–
Encoder (6 terminals)
- VCC
- EGND
- EA+, EA–
- EB+, EB–
- ENA+, ENA– : Enable input
- DIR+, DIR– : Direction input
- PUL+, PUL– : Step pulse input
- ALM+, ALM– : Alarm output (fault status)
| Pulses/Rev | SW3 | SW4 | SW5 | SW6 |
| Default | on | on | on | on |
| 10000 | off | on | off | off |
** Key Features **
- Closed-loop stepper control with encoder feedback
- Prevents lost steps and provides stall detection
- Alarm output via ALM pins
- Uses standard Step/Dir interface (compatible with AXBB-E controller)
- Optimized for NEMA 23/24 closed-loop stepper motors
Photos of Z Servo Driver
- Model: MA860H
- Type: 2-phase digital stepper driver
- Voltage Range: 18–80 VAC or 24–110 VDC
- Microstepping Resolution: Up to 40,000 pulses/rev
- Peak Current Output: Up to 7.2 A
Connections
Signal Inputs
- DIR+ / DIR– : Direction control input
- PUL+ / PUL– : Step pulse input
- ENA+ / ENA– : Enable input
Motor Outputs
- A+, A– : Motor phase A
- B+, B– : Motor phase B
Power Supply
- AC ~ terminals : 18–80 VAC input
- DC terminals : 24–110 VDC input
- Motor Current Setting (SW1-SW3 = 000): 6.0 A RMS / 7.2 A peak maximum current
- Idle Current (SW4 = 0): Half-current hold mode (reduced current when idle)
- Microstep Resolution (SW5-SW8 = 0100): 10,000 pulses/rev (≈ 1/50 microstepping for a 1.8° stepper)
Key Features
- High-voltage, high-current driver for large stepper motors (NEMA 34 class)
- Microstepping up to 1/128 (40,000 pulses/rev)
- Automatic idle current reduction (via SW4)
- Step/Dir/Enable compatible with AXBB-E motion controller
- Used exclusively for the Z axis on the Jaxen CNC
3. Ethernet Motion Controller
- Function: Interfaces between UCCNC on your PC (via Ethernet) and the motor drivers, limit switches, and I/O.
- Ports:
- Port 1 (Isolated Outputs): Sends step/dir/ena signals to the motor drivers.
- Port 2 (Isolated Inputs): Reads signals from limit switches, homing switches, estop, etc.
- Port 3 (Non-Isolated Inputs/Outputs): General-purpose inputs/outputs.
- 24V/5V Power In: Supplied from the Mean Well MDR units.
- Status LEDs show link, power, and I/O states.
- Expands I/O from the AXBB-E.
- Provides screw terminals for clean connection of inputs (limit switches, probe, estop) and outputs (coolant pump, spindle relay, etc.).
- Optoisolated for noise protection.
5. Motors
X and Y axis Motors
** XY Motor Identification**
- Model: 57HSE2N-D25
- Type: Hybrid stepper motor with integrated encoder
- Manufacturer: JSS Motor (as labeled on the tag: “JSS MOTOR NO:201701”)
** XY Motor Leads**
- The motor side has the usual 4-lead bipolar wiring:
- A+ = Red
- A- = Green
- B+ = Yellow
- B- = Blue
** XY Encoder Leads**
- The encoder provides feedback for closed-loop control:
- EA+ = Black
- EA- = Blue
- EB+ = Yellow
- EB- = Green
- VCC = Red (supply power for encoder, usually 5 V)
- EGND = White (encoder ground)
Typical Wiring Diagram
| Attribute | Value (typical) |
| Frame Size | NEMA 23 (57 mm) |
| Step Angle | 1.8° (200 steps/rev) |
| Holding Torque | ~2.0–2.5 Nm (280–350 oz-in) |
| Rated Current | ~4.0–5.0 A/phase |
| Resistance | ~0.5–0.8 Ω/phase |
| Inductance | ~2.5–4.0 mH |
| Encoder Resolution | 1000–2500 PPR (typical, quadrature) |
| Voltage Drive | 48 V DC (as supplied by your Mean Well NDR-480-48 PSU) |
- XY axis are closed-loop stepper motors—sometimes marketed as servo-stepper hybrids—which combine the simplicity of stepper drive with the position assurance of encoder feedback.
Function in Your CNC (Jaxen)
- X Axis Motor: Moves the table left/right (long axis).
- Y Axis Motor: Moves the table front/back (short axis).
- Both motors receive step/dir signals from the CNCdrive AXBB-E motion controller via the blue motor drivers you showed earlier.
Z Axis Motor not documented
Limit Switch Configuration
Physical Layout
- X Axis → Limit switch at the X− end (left side when facing the machine).
- Y Axis → Limit switch at the Y− end (front of the table).
- Z Axis → Limit switch at the Z+ end (top of spindle travel).
Function in UCCNC
- During homing, the axis moves toward the limit switch until it triggers, then backs off to establish machine zero.
- During normal operation, the same switch acts as a hardware limit in that direction.
- The opposite end of travel is protected using software soft limits, defined in UCCNC machine setup.
- Each axis (X, Y, Z) has independent limit switches routed through the breakout board.
- Output signals can be wire-OR’d, allowing multiple switches per axis if needed.
- The breakout board is wired into the AXBB-E motion controller.
- Designed for reliability in CNC environments with high electrical interference.
- Creltek Datasheet: Creltek RJ-11 Sensor Breakout v2.1 Datasheet
| Feature | Description |
| Name | Creltek RJ-11 Sensor Breakout Board v2.1 (by Kevin H. Patterson) |
| Connectors | 8 × RJ-11 jacks (each with power, ground, and signal) |
| Outputs | Active-low, open-collector, capable of sinking >200 mA |
| Pull-ups | Optional on-board 4.7 kΩ pull-up resistors |
| Noise Filtering | Built-in circuitry for robust operation in electrically noisy environments |
| Voltage Support | Native 3.3 V, or 5–18 V with onboard regulator |
| Mounting | Panel-mount capable; designed for professional installation |
8. Spindle Feedback Encoder
- Model: E38S6G5-600Z
- Type: Incremental rotary encoder
- Body size: 38 mm diameter
- Mounting: Solid shaft, direct-coupled to spindle
- Resolution: 600 pulses per revolution (P/R)
- Channels: A, B (quadrature) + Z (index pulse, 1 per revolution)
- Supply voltage: 5–24 VDC
- Output type: Line driver / push-pull TTL (depending on wiring)
- Shaft: Solid, 6 mm or 8 mm diameter (variant dependent)
- Output signals: Differential A, B, Z for accurate detection
Function
- Provides real-time spindle speed feedback to the motion controller (AXBB-E).
- Index pulse (Z) can be used for precise synchronization tasks:
- Rigid tapping
- Thread cutting
- Accurate spindle homing
References
9. Spindle Control Board
10. E-Stop
tbd
11. Tool Offset Sensor
| Parameter | Specification |
| Model | MY20-20-2 |
| Type | Automatic tool setter / touch sensor |
| Operating voltage | 24 VDC (nominal, 5–24 V compatible) |
| Contact type | Normally Closed (NC) |
| Construction | Anodized aluminum body, carbide plunger |
| Plunger travel | ~2 mm (spring loaded) |
| Repeatability | ±0.001 mm |
| Output signal | Switch closure (opens on touch) |
| Wiring | 2-wire NC switch: +24 V → sensor → AXBB-E input (I±) |
| Recommended AXBB-E input | Isolated input (e.g. I6+ / I6-) |
| UCCNC configuration | Assign as Probe input |
| Application | Automatic tool length offset, tool change probing |
| Notes | Wire as NC for fail-safe; if cable breaks, UCCNC sees an open input (probe tripped). |
12. PC & UCCNC Software
- UCCNC software (Windows 10) generates the motion control stream.
- Sends commands (steps/directions) over Ethernet to the AXBB-E.
- The AXBB-E translates them into hardware pulses for the drivers.
- Operator inputs (limit switches, estop, spindle control) feed back to UCCNC via the AXBB-E.
Signal Flow Summary
- Mains AC → Power Supplies → Provide 48V (motors), 24V (control), 5V (logic).
- PC running UCCNC → Ethernet → AXBB-E Motion Controller.
- AXBB-E Outputs → Step/Dir/Ena → Motor Drivers (X, Y, Z, A).
- Motor Drivers → High-voltage pulses → Stepper Motors.
- AXBB-E Inputs ← Limit switches, estop, home sensors.
- Optional: Outputs control spindle, coolant, etc.
