- keeping users safe
- Workpiece holding
- Startup procedure
- G-Code Workspaces
- Sign up for Jaxen training. It's strongly suggested you first do training on the smaller CNC 'Bobby'.
- On your training day 1:
- Do the exam verbally at the end of this page.
- You pass with 10/12 correct answers.
- Training Day 2:
- Your name is added to the list of trained people TODO where will this be???
- Your first personal project:
- For your first project, you must discuss your project plan with a CNC committee member who is currently offering training. This is to help you apply the skills you learned from the training to new scenarios. Also, experienced members can help you get what you want: either fast production, or high quality. Be sure to tell them what you want.
- Your 2nd and later projects:
- On your second and later projects, you are encouraged to ask for advice, but you can begin using the machine without the need for permission, while still minding other's access to the machine. By then, you'll have enough experience, you'll probably be teaching us!
- Sign in on the log book before you start working!
- Listen to the sound of the mill. Squealing means that something is vibrating, and will negatively impact your finish or part tolerances.
- If you're a committee member and modifying the machine, check and update Jaxen's homepage!
- Wipe the vice before clamping. Chips between metal cause dimension errors.
- Tap the workpiece into the vice- must be resting on parallels- this eliminates “vice-lift” (Jaxen's vice is pretty resistant to this, but it's still good practice).
- Sign in by writing your name and date on the paper log. This is so you can see what else is happening with this shared machine.
- Boot the PC
- Login to the PC
- Home the machine
- Shutdown PC
- Power off the CNC (unplug)
Squaring Stock
Facing/Surfacing
- Vice bolted to the table
- Your part does not have at least 2 parallel faces that are rigid enough to be load bearing.
Tool Bit Examples
- End mill
- Chamfer/bevel
- Ball mill
- Arbour/Shell mill
TODO make into table
- Aluminum: WD40 (optional)
- Steel: Tap Magic
- Stainless-Steel: Anchorlube Metalworking Compound (not yet tested on Jaxen)
Material Tips:
Maintenance involves:
- Maintaining the core Grizzly Milling Machine. Refer to the original manual on lubrication practices.
- Checking that limit switch brackets are tight and homing correctly (there are 3 brackets).
- Watching for stepper driver overload faults (axis stops moving until power cycle).
- Listening for noisy fans clogged with dust.
- Updating Windows on the computer, and FreeCAD.
General Maintenance Tips:
For lubricating gears or parts that have high forces between them (normal to the surface that the grease is on, not sliding across): use High-pressure grease. Blondiehacks reccommends: MAG1 High Temp Disc Brake Wheel Bearing Grease Lithium Complex https://www.youtube.com/watch?v=x8tx-cBulno
- Click “Add to Job”
Engraving Tips
- Make your part/body first as normal
- Go to Draft workbench, and create a ShapeString. It won't be on the face you want, but that's OK.
- Move the ShapeString object to be on the face you want- the Z axis is what's important. One way is by using the parameters in the left panel.
- Adjust any other settings like scale and rotation.
- Return to the Part workbench.
- Drag and drop the ShapeString object onto the Body object of your part, so that it becomes associated.
- You can now proceed to use the ShapeString to make features and toolpaths.
Jaxen training demo project
- Getting good surface finish
- Verifying dimensions
- Through-hole opening
- Engraving
- Chamfer
- Work from the inside out, because the outer material is what typically touches the vice, and also the perimeter is usually more volumeous than the inner parts, so it makes the part more rigid for longer during the job.
- Do blind pockets in steps, because the deeper any single pass, the more the bit will vibrate, and this makes the walls rough.
- The final pass should always be very thin for the best finish. 0.1mm finishing pass usually works well.
- When designing your CAD, inside corner radii are limited! Keep in mind the radius of your toolbits.
- Absolute: G90
- Relative: G91
- Absolute positioning: G90
- Relative positioning: G91
- Rapid move: G0 x50
- s1000
- G54 = User defined #1
- G55 = User defined #2
- G56 = User defined #3
- G59 #6 = User defined #6
- The shape of your stock
The general steps are:
- Pick an axis to find
- Save this position:
- Repeat for the other axes.
Variations:
- Use an edge finding tool.
Practice!
- Click REWIND FILE
- Do whatever you need while the machine is paused. Move workholding/workpiece, or manually jog the machine.
- HOWEVER: be careful of executing G-Code in this state! Your program may be depending on mode G90 or G91, and any other settings, and won't know if you change them!
- What is the most important thing (that was taught to you during training) to prevent when installing/removing collets?
- What is the most important thing (that was taught to you during training) to prevent after installing/removing collets?
- What does G54 mean?
- You are planning a surfacing operation in CAM. What resources can you consult to figure out an appropriate feed rate of the tool?
