Visit Jaxen's homepage here.
  • keeping users safe
  • Workpiece holding
  • Startup procedure
  • G-Code Workspaces
  • Sign up for Jaxen training. It's strongly suggested you first do training on the smaller CNC 'Bobby'.
  • On your training day 1:
  • Training Day 2:
  • Listen to the sound of the mill. Squealing means that something is vibrating, and will negatively impact your finish or part tolerances.
  • Tap the workpiece into the vice- must be resting on parallels- this eliminates “vice-lift” (Jaxen's vice is pretty resistant to this, but it's still good practice).
  • Sign in by writing your name and date on the paper log. This is so you can see what else is happening with this shared machine.
  • Boot the PC
  • Power on the electrical panel (Plug in the cord)
  • Power on the spindle driver system (Plug in the cord)
  • Turn on the enclosure lights.
  • Check that the enclosure is free of obstructions- NO STORAGE is permitted in the enclosure.
  • Check that the vice, table, and slides are clean of chips. Wipe them away if not.
  • Login to the PC
  • Open UCCNC from the desktop shortcut, so that the profile “Jaxen Metric” is loaded.
  • Click the red/yellow reset button in UCCNC
  • Home the machine
  • Continue to mount your workpiece as you see fit…
  • Move the Z axis up and away from the table.
  • Clean up! Vacuum and/or wipe the vice. There should be ZERO chips on the jaws or top of the vice, and clean to the touch.
  • Shutdown PC
  • Power off the CNC (unplug)
  • Follow the setup in reverse order…
  • Hand on the draw bar bolt head (coming out of the top of the spindle).
  • At least 1 finger on the collet.
  • At least 1 finger on the bit inside the collet.
  • First hand tighen the bolt on the top of the “draw bar”,
  • Then 1/4 turn the screw with wrench and allen key,
  • Then REMOVE the allen key immediately!!
Squaring Stock
Facing/Surfacing
  • Vice bolted to the table
  • holds the part using a bolt,
  • but also serves as accurate positioning to easily place the part, even preparing for repeated jobs.
  • Your part does not have at least 2 parallel faces that are rigid enough to be load bearing.
Tool Bit Examples
  • End mill
  • Chamfer/bevel
  • Ball mill
  • Arbour/Shell mill
TODO make into table
  • Aluminum: WD40 (optional)
  • Steel: Tap Magic
  • Stainless-Steel: Anchorlube Metalworking Compound (not yet tested on Jaxen)
Material Tips:
Maintenance involves:
  • Maintaining the core Grizzly Milling Machine. Refer to the original manual on lubrication practices.
  • Watching for stepper driver overload faults (axis stops moving until power cycle).
  • Listening for noisy fans clogged with dust.
  • Updating Windows on the computer, and FreeCAD.
General Maintenance Tips:
For lubricating gears or parts that have high forces between them (normal to the surface that the grease is on, not sliding across): use High-pressure grease. Blondiehacks reccommends: MAG1 High Temp Disc Brake Wheel Bearing Grease Lithium Complex https://www.youtube.com/watch?v=x8tx-cBulno
  • Switch to the CAM workbench.
  • First, you need to create a new job using the “Job” button. You'll then have a docked wizard menu “Tasks” on the right to setup the overall job.
  • In the lower right corner of the window, make sure the units are set to “Metric small parts CNC”. (You may get a warning about this if not).
  • Recommended to order by operation and Split output. This makes troubleshooting easier when you're actually running the GCode later.
  • You need to pick a point on your model or the stock bounding box to specify the origin! Click and then Setup > Set Origin.
  • Also note the position of your model in the stock- make sure this is set correctly.
  • You can now close the Job wizard.
  • In the left model organizer pane, delete the default tool added by the Job wizard.
  • In the toolbar, click the “Add Toolbit” button.
  • In the Toolbit selector window, you'll see all the bits loaded in the library for this FreeCAD installation.
  • When picking a bit, be sure to check ALL properties of the bit you choose to make sure that it's what you expect! Right-click on the bit, then click “edit” to view the detailed properties.
    • The bits commonly used on Jaxen will already be in the library- it is a global list.
  • Click “Add to Job”
  • Double click “SetupSheet” in the Model organizer
  • Scroll to bottom, set the “step down” to your desired depth of cut: probably something like 0.2mm - 0.5mm
  • Single click “SetupSheet” and set the Clearance and Safe heights both to 5mm, or whatever you deem to be safe. Notice how this will update the fields in the right pane. Note that this distance will be travelled by a G1 move, so it'll take a long time if you make it too big!
  • In section “Tool Controller” set the rapid speeds to Jaxen's standard Rapid speeds (note Rapid speeds are for when you're NOT cutting).
  • TODO verify if this actually overrides UCCNC's G0 feed rates….
  • Again, confirm that the rapid speeds update in the right pane. You may need to click in each box.
  • Click OK to close the right pane (SetupSheet tasks view).
  • Back in the Model Organizer, click your tool (the parent item starting with “TC”)
  • Set your Feed rates: this time for cutting. Refer to Jaxen's job log, or the linked tables in Jaxen's Operating guide page for what to put! For steel, 30mm/min is a good safe minimum for Horiz feed.
  • Set your “Spindle speed”: again, refer to Jaxen's job log, or a public feed-speed chart. 1000 RPM is typical for Jaxen.
  • Select the geometry of your model that will be relevant to this operation. In this case, select the face you want to surface!
  • Then click “Face” button in the toolbar.
  • For a nice finish on stock, suggested settings: stepover 80%, Clear edges, perimeter.
  • Click OK to exit the Task creation. You should now see your toolpaths in the viewport.
  • View the simulation of your job: click the “CAM Simulator” button in the toolbar. When done, be sure to CLOSE the simulator before going back to editing in FreeCAD or it may crash!
  • Export your GCode: Click the “Post Process” button. Click OK in the window to save your code to a file (default is same directory as the FreeCad file).
Engraving Tips
  • Make your part/body first as normal
  • Go to Draft workbench, and create a ShapeString. It won't be on the face you want, but that's OK.
  • Move the ShapeString object to be on the face you want- the Z axis is what's important. One way is by using the parameters in the left panel.
  • Adjust any other settings like scale and rotation.
  • Return to the Part workbench.
  • Drag and drop the ShapeString object onto the Body object of your part, so that it becomes associated.
  • You can now proceed to use the ShapeString to make features and toolpaths.
Jaxen training demo project
  • Getting good surface finish
  • Verifying dimensions
  • Through-hole opening
  • Engraving
  • Chamfer
  • Absolute: G90
  • Relative: G91
  • Absolute positioning: G90
  • Relative positioning: G91
  • Rapid move: G0 x50
  • s1000
  • G54 = User defined #1
  • G55 = User defined #2
  • G56 = User defined #3
  • G59 #6 = User defined #6
  • The shape of your stock
The general steps are:
  • Pick an axis to find
  • Jog the spindle to a few mm away from the workpiece surface you want to use as your reference.
  • Insert an object of a known thickness between the tool and workpiece, such as a shim or paper.
  • Move the tool to close the gap very slowly (1% of default jog speed) until the object is pinched.
  • Apply math to convert the tool's current position to the origin point:
  • Save this position:
  • Repeat for the other axes.
Variations:
  • Use an edge finding tool.
Practice!
  • Scroll all the way to the top
  • Click REWIND FILE
  • Double check the work area is clear to begin automatic movement
  • Click the CYCLE START button.
  • During your operation, click CYCLE STOP when you are just at the boundary of 2 lines of G-Code operating. Doesn't matter whether you're at the end of one or beginning of the one you want to resume in.
  • Do whatever you need while the machine is paused. Move workholding/workpiece, or manually jog the machine.
    • HOWEVER: be careful of executing G-Code in this state! Your program may be depending on mode G90 or G91, and any other settings, and won't know if you change them!
  • Jog the machine back to the start of where you want to resume.
  • Scroll in the GCode window to highlight the line and feature you want to resume at the start of.
  • Click RUN FROM HERE. A message will be printed in the console to confirm.
  • Click CYCLE START. A window will appear.
    • Check “switch spindle on first”
    • Check that feed rate is the same as what the GCode was doing.
    • When you click OK, UCNC will do a G1 move from wherever you are to the start of the operation.
  • Wait for the setup move to complete.
  • The tool is now in position at exactly the start of the GCode line.
  • Click CYCLE START again to resume your operation
  • Where are three buttons you can push to stop the machine?
  • What is the most important thing (that was taught to you during training) to prevent when installing/removing collets?
  • What is the most important thing (that was taught to you during training) to prevent after installing/removing collets?
  • What type of collets go directly into Jaxen's spindle?
  • Why shouldn't you home the machine between operations?
  • Why do the steppers appear to jump when changing direction?
  • What kind of precision can you expect to get with Jaxen?
  • You want to move the spindle 5mm to the right. You type “G0 x5”. What should you do before this?
  • What does G54 mean?
  • When doing a touch-off procedure for the Y axis, what's the formula to convert spindle position to position of the workpiece edge?
  • What happens if you jog the X axis all the way to the left? All the way to the right?
  • You are planning a surfacing operation in CAM. What resources can you consult to figure out an appropriate feed rate of the tool?
wiki/tools/jaxen_operating.1790838353.txt.gz · Last modified: 2026/10/01 00:05
