- keeping users safe
- Workpiece holding
- Startup procedure
- G-Code Workspaces
- Sign up for Jaxen training
- On your training day 1:
- Do the exam verbally at the end of this page.
- You pass with 10/12 correct answers.
- Training Day 2:
- Your name is added to the list of trained people TODO where will this be???
- Your first personal project:
- For your first project, you must discuss your project plan with a CNC committee member who is currently offering training. This is to help you apply the skills you learned from the training to new scenarios. Also, experienced members can help you get what you want: either fast production, or high quality. Be sure to tell them what you want.
- Your 2nd and later projects:
- On your second and later projects, you are encouraged to ask for advice, but you can begin using the machine without the need for permission, while still minding other's access to the machine. By then, you'll have enough experience, you'll probably be teaching us!
- Sign in on the log book before you start working!
- If you're a committee member and modifying the machine, check and update Jaxen's homepage!
- Wipe the vice before clamping. Chips between metal cause dimension errors.
- Tap the workpiece into the vice- must be resting on parallels- this eliminates “vice-lift” (Jaxen's vice is pretty resistant to this, but it's still good practice).
- Sign in by writing your name and date on the paper log. This is so you can see what else is happening with this shared machine.
- Boot the PC
- Login to the PC
- Home the machine
- Shutdown PC
- Power off the CNC (unplug)
Squaring Stock
Facing/Surfacing
- Vice bolted to the table
- Your part does not have at least 2 parallel faces that are rigid enough to be load bearing.
Bits:
- End mill
- Chamfer/bevel
- Ball mill
- Arbour/Shell mill
- Aluminum: WD40 (optional)
- Steel: Tap Magic
- Stainless-Steel: Anchorlube Metalworking Compound
Materials:
- Click “Add to Job”
Jaxen training demo project
- Getting good surface finish
- Verifying dimensions
- Through-hole opening
- Engraving
- Chamfer
- Work from the inside out, because the outer material is what typically touches the vice, and also the perimeter is usually more volumeous than the inner parts, so it makes the part more rigid for longer during the job.
- Do blind pockets in steps, because the deeper any single pass, the more the bit will vibrate, and this makes the walls rough.
- The final pass should always be very thin for the best finish. 0.1mm finishing pass usually works well.
- When designing your CAD, inside corner radii are limited! Keep in mind the radius of your toolbits.
- Absolute: G90
- Relative: G91
- Absolute positioning: G90
- Relative positioning: G91
- Rapid move: G0 x50
- s1000
- G54 = User defined #1
- G55 = User defined #2
- G56 = User defined #3
- G59 #6 = User defined #6
- The shape of your stock
The general steps are:
- Pick an axis to find
- Save this position:
- Repeat for the other axes.
Variations:
- Use an edge finding tool.
Practice!
- Click REWIND FILE
- Do whatever you need while the machine is paused. Move workholding/workpiece, or manually jog the machine.
- HOWEVER: be careful of executing G-Code in this state! Your program may be depending on mode G90 or G91, and any other settings, and won't know if you change them!
- What is the most important thing to prevent when installing/removing collets?
- What is the most important thing to prevent after installing/removing collets?
- What does G54 mean?
- You are planning a surfacing operation in CAM. What resources can you consult to figure out a feed rate of the tool?
Temp job log notes:
Climb cutting even for side-milling makes a noticable difference. Always climb cut side faces.
Sep 6 facing steel plate. Should be all same specs as before, but this time plate is flat, so depth is even across whole operation. 1000 rpm, 30mm/min. No lip between passes!
2nd half: switched to 1400 rpm result: no visible difference, may cause finish to change faster
observations between climb and conventional: there may be a relationship to the time into the pass. The circular swirl pattern gets more significant later on during the pass, maybe due to buildup of chips.
The actual left/right side of pass does not seem to matter- the overlap of the swirl pattern appears to be due to minor changes in surface height.
Making passes in the same direction each time does seem like it would provide better finish.
