- keeping users safe
- Workpiece holding
- Startup procedure
- G-Code Workspaces
- First, complete training on the smaller CNC “Bobby-Fett”.
- Sign up for Jaxen training
- On your training day 1:
- Get verbally tested on the training material
- You pass with 9/12 correct answers.
- Training Day 2:
- Must wipe the vice before clamping. Chips between metal cause dimension errors.
- Tap the stock into the vice- must be resting on parallels- this eliminates “vice-lift”.
- Boot the PC
- Login to the PC
- Home the machine
- Shutdown PC
- Power off the CNC (unplug)
Squaring stock:
Facing:
- Vice bolted to the table
- Less than 2 parallel faces of your finished part are stock
Bits:
- End mill
- Chamfer/bevel
- Ball mill
- Arbour/Shell mill
- Aluminum: WD40 (optional)
- Steel: Tap Magic
- Stainless-Steel: Anchorlube Metalworking Compound
Materials:
- Click “Add to Job”
Jaxen training demo project
- Getting good surface finish
- Verifying dimensions
- Through-hole opening
- Engraving
- Chamfer
-Work from the inside out, because the outer material is what typically touches the vice, and also the perimeter is usually more volumeous than the inner parts, so it makes the part more rigid for longer during the job.
-Do blind pockets in steps, because the deeper any single pass, the more the bit will vibrate, and this makes the walls rough.
Additionally, the final pass should always be very thin for the best finish. 0.1mm finishing pass usually works well.
TODO Job prep: For example, choosing inside corner radii based on bits used.
- Absolute: G90
- Relative: G91
- Absolute positioning: G90
- Relative positioning: G91
- Rapid move: G0 x50
- s1000
- G54 = User defined #1
- G55 = User defined #2
- G56 = User defined #3
- G59 #6 = User defined #6
- The shape of your stock
The general steps are:
- Pick an axis to find
- Save this position:
- Repeat for the other axes.
Variations:
- Use an edge finding tool.
Practice!
- Click REWIND FILE
- Do whatever you need while the machine is paused. Move workholding, manually jog the machine, adjust workspace origin, etc.
- What is the most important thing to prevent when installing/removing collets?
- What is the most important thing to prevent after installing/removing collets?
- What does G54 mean?
- You are planning a surfacing operation in CAM. What resources can you consult to figure out a feed rate of the tool?
