- keeping users safe
- Workpiece holding
- Re-mounting parts between jobs accurately (basics)
- Startup procedure
- G-Code Workspaces
CAD:
- Constructability
- Basic examples of what type of CAD job to use to achieve design features
- First, complete training on the smaller CNC “Bobby-Fett”.
- Sign up for Jaxen training
- On your training day 1:
- Get verbally tested on the training material
- You pass with 9/12 correct answers.
- Training Day 2:
- Must wipe the vice before clamping. Chips between metal cause dimension errors.
- Tap the stock into the vice- must be resting on parallels- this eliminates “vice-lift”.
- Boot the PC
- Login to the PC
- Home the machine
- Shutdown PC
- Power off the CNC (unplug)
Squaring stock:
Facing:
- Vice bolted to the table
- Less than 2 parallel faces of your finished part are stock
Bits:
- End mill
- Chamfer/bevel
- Ball mill
- Arbour/Shell mill
- Aluminum: WD40 (optional)
- Steel: Tap Magic
- Stainless-Steel: Anchorlube Metalworking Compound
Materials:
- Click “Add to Job”
-Work from the inside out, because the outer material is what typically touches the vice, and also the perimeter is usually more volumeous than the inner parts, so it makes the part more rigid for longer during the job.
-Do blind pockets in steps, because the deeper any single pass, the more the bit will vibrate, and this makes the walls rough.
Additionally, the final pass should always be very thin for the best finish. 0.1mm finishing pass usually works well.
TODO Job prep: For example, choosing inside corner radii based on bits used.
- G54 = User defined #1
- G55 = User defined #2
- G56 = User defined #3
- G59 #6 = User defined #6
WARNING: when axis is homed, any error corrected will cause all workspaces to shift by that amount! DO NOT HOME the machine between operations! This is because all user-defined workspaces are relative to/nested inside Workspace #0. However, they are not all nested within each other consecuitively. Example: Workspace #2 is not affected by workspace #1, only Workspace #0.
Currently, the hardlimits on Jaxen are providing about 0.005mm repeatability. You can see this when you see the machine coordinates being non-zero as the machine stops on the limit switches during homing.
There is one more offset: the “tool offset” which is nested in every workspace. It only affects Z. Note that this is not the same as “tool radius compensation”.
In UCCNC: In the “Main” window 3D view, the blue pointer represents the origin of the SELECTED workspace. The yellow is the actual toolbit location relative to the selected workspace.
Setting workspace coordinates:
Do this before starting to execute CAM GCode.
In the CAM software, usually it will say what workspace # you are exporting for.
In UCCNC, activate the workspace you want:
G54
Then, manually move the bit to the origin point you want to use. (using the “manual drive” buttons in UCCNC)
Then you need to save this position into UCNC as the origin for Workspace #1. Do this by typing the command:
G92 x0 y0 z0 OR you can click “ZERO ALL” blue button.
The current position is now set to be the origin for Workspace #1.
A G0 is used for a “rapid move” (at the machine's native feed rate). The controller will decide the best way to get to destination. For example, it will always move Z up first before X/Y. G0 always uses the machine's built-in feed rates.
A G1 is used for cutting (interpolated). G1 uses the last feed rate specified (in the loaded GCode, or manually entered).
- Absolute: G90
- Relative: G91
- Absolute positioning: G90
- Relative positioning: G91
- Rapid move: G0 x50
- s1000
- Click REWIND FILE
- Do whatever you need while the machine is paused. Move workholding, manually jog the machine, adjust workspace origin, etc.
- What is the most important thing to prevent when installing/removing collets?
- What is the most important thing to prevent after installing/removing collets?
- What does G54 mean?
- You are planning a surfacing operation in CAM. What resources can you consult to figure out a feed rate of the tool?
