Page is under construction by colinl. Work in progress.
- keeping users safe
- training material
This page is only for Jaxen, although some general info about milling may apply to other CNC machines. Started by colinl.
todo: add link to member-written guides.
Training Program
- General policies, access, and group communication when using Jaxen CNC.
- Basics of Milling (advanced milling not in scope)
- Workpiece holding
- Re-mounting parts between jobs accurately
- How to 'drive' Jaxen with UCCNC
- Understanding basic G-Code for troubleshooting and manual data entry
- G-Code Workspaces
- Tool depth calibration
- Running jobs
CAD:
- Constructability
- Basic examples of what type of CAD job to use to achieve design features
Basic Reminders:
- Must clean the vice before clamping. Chips between metal cause dimension errors.
- Clean calipers before measuring. Same reason.
- Tap the stock into the vice- must be resting on parallels- this eliminates “vice-lift”.
- Chip control- don't cut chips. Get them out of the path of the bit somehow (coolant to be added)
Basic Milling Procedures:
Installing collets into the spindle:
Put lower fingers on the bit, upper fingers on the collet. When installing a collet, put it in by hand first, then hand tighen the bolt on the top of the “draw bar”, then 1/4 turn with wrench, then REMOVE allen key immediately!!
Always ensure the Allen Key is out of the top screw after tightening spindle!!!
Squaring stock:
Slots:
Additional issue is chip control, gets worse for deeper slots.
Facing:
Speed and feed resources:
Used by myelophone: https://www.autodrill.com/resources/recommended-tool-speed-chart Notes: above assumes: HSS tools, appropriate coolant (although says you can reduce RPM by 25% to not use coolant in “most metals”, stainless requires more reduction).
Why is workholding needed?
- but also serves as actuate positioning to easily place the part, even preparing for repeated jobs.
- Less than 2 parallel faces of your finished part are stock
The standard mounting method currently is M6 threaded holes spaced 10mm apart, passing through non-threaded holes in your workpiece. Reccommended to use hex bolt heads so that the head can be as large as possible wihtout needed to use a wrench because it would hit adjacent bolt heads.
You will need to drill an exact-sized hole in your stock to fit snugly on the M6 bolt. Reccommended: 15/64 in == 5.95mm. The M6 bolt should be snug, but just barely slide through the hole in your workpiece. Then, you'll need to use the existing threaded mounting holes in the bed, or make new ones:
First drill pilot holes with a 1/8 bit in the mill for accurate pilot hole locations.
Then a 13/64in (5.16mm) bit on other machine/drill to prepare for tapping, (because it's harder to find a collet for)
Or you can use the R8 drill chuck to directly drill this hole on the mill.
then tapped using an M6 tap.
Bits:
Types: Arbour/Shell mill? Chamfer/bevel Ball mill End mill
R8 collet > 1/8 bit - examples: V bits 20deg, gold cordcob endmills,
Aluminum: WD40 Stainless-Steel: Anchorlube Metalworking Compound
Materials:
G-Code:
General tips:
Job prep: For example, choosing inside corner radii based on bits used.
-Work from the inside out, because the outer material is what typically touches the vice, and also the perimeter is usually more volumeous than the inner parts, so it makes the part more rigid for longer during the job.
-Do blind pockets in steps, because the deeper any single pass, the more the bit will vibrate, and this makes the walls rough. Additionally, the final pass should be very thin for the best finish.
-When running your code in UCCNC, you click the CYCLE START button. BE CAREFUL that this actually starts from the current line! If you scrolled your file, or partially ran your code before, it will resume, not restart!!
M6 = Tool change. Usually exported b FreeCAD, but ignored for our machine. M3 sNNNN = set spindle RPM
Note that the GCode can be specified in: Absolute: G90 Relative: G91
G53 #0 = Machine Coordinates, where 0,0,0= the homing position. G54 #1 = User defined #1. G55 #2 = User defined #2 … G59 #6 = User defined #6 WARNING: when axis is homed, any error corrected will cause all workspaces to shift by that amount! DO NOT HOME the machine between operations! This is because all user-defined workspaces are relative to/nested inside Workspace #0. However, they are not all nested within each other consecuitively. Example: Workspace #2 is not affected by workspace #1, only Workspace #0.
There is one more offset: the “tool offset” which is nested in every workspace. It only affects Z. Note that this is not the same as “tool radius compensation”.
In UCCNC: In the “Main” window 3D view, the blue pointer represents the origin of the SELECTED workspace. The yellow is the actual toolbit location relative to the selected workspace.
Setting workspace coordinates: Do this before starting to execute CAM GCode. In the CAM software, usually it will say what workspace # you are exporting for. In UCCNC, activate the workspace you want: G54 Then, manually move the bit to the origin point you want to use. (using the “manual drive” buttons in UCCNC) Then you need to save this position into UCNC as the origin for Workspace #1. Do this by typing the command: G92 x0 y0 z0 OR you can click “ZERO ALL” blue button. The current position is now set to be the origin for Workspace #1.
A G0 is used for a “rapid move” (at the machine's native feed rate) Theory: a G0 move will not necessarily be a straight line: each axis moves independently and max-out speed independently. The controller will decide the best way to get to destination. For example, it will always move Z up first before X/Y???? And then a G1 is used for cutting (interpolated) Also, G0 uses the machine's built-in feed rates, whereas G1 uses the last feed rate specified.
For semi-manual G-Code, cheatsheet: MDI = Manual Data Input box First check: #Relative positioning: G91 #Interpolated move: G1 F1 Z1
