Page is under construction by colinl. Work in progress.
This page documents common procedures on Jaxen. Purposes of this guide:
- keeping users safe
- training material
This page is only for Jaxen, although some general info about milling may apply to other CNC machines. Started by colinl.
Basic Reminders:
Must clean the vice before clamping. Chips between metal cause dimension errors.
Clean calipers before measuring. Same reason.
Tap the stock into the vice- must be resting on parallels- this eliminates “vice-lift”.
Don't let the cutter bit fall out! It's a 3 hand job. Put lower finger on the bit, upper fingers on the collet. When installing a collet, put it in by hand first, hand tighen, then 1/4 turn with wrench, then REMOVE allen key immediately!!
Chip control- don't cut chips. Get them out of the path of the bit.
Basic Procedures:
Squaring stock: Identify the flattest faces to use as clamping faces, then face the roughest first. Next, put this newly faced face against the jaws, and face the next face, 90* from the first.
Top-hat method: Good for when you don't need fully-faced sizes, but complete top and bottoms. (There is no way to accurately face the full sides using this method)
Slots: For plunging, you need an endmill with center-cutting ability (no center hole). When plunging, the bit will vibrate, causing hole size to be slightly larger than the bit's size. Width of slot is dependent on rigidity of machine. Blondiehacks example: 1/4“ cutter, 1/8” steel plate. For ideal finish, make a slot in 3 passes: 1 smaller rough pass, then go back around the edges to get final dimension (3thou is a good amount to take off)
Blind Slots: Additional issue is chip control, gets worse for deeper slots.
Facing: If you climb-cut a face around the edges, it won't produce a burr, because the burr is sucked inwards and naturally cut off.
Speed and feed resources: Used by myelophone: https://www.autodrill.com/resources/recommended-tool-speed-chart Notes: above assumes: HSS tools, appropriate coolant (although says you can reduce RPM by 25% to not use coolant in “most metals”, stainless requires more reduction).
Why is workholding needed? If you're going to be milling all sides of your part, you can't clamp your part in a vice. You'll need to hold it by it's middle somehow. Examples: gears, oddly-shaped flat parts, etc. By using a standard hole, this has 2 functions: - holds the part using a bolt, - but also serves as actuate positioning to easily place the part, even preparing for repeated jobs.
The standard mounting method currently is M6 threaded holes spaced 10mm apart, passing through non-threaded holes in your workpiece. Reccommended to use hex bolt heads so that the head can be as large as possible wihtout needed to use a wrench because it would hit adjacent bolt heads.
Preparing workholding for your project: You will need to drill an exact-sized hole in your stock to fit snugly on the M6 bolt. Reccommended: 15/64 in == 5.95mm. The M6 bolt should be snug, but just barely slide through the hole in your workpiece. Then, you'll need to use the existing threaded mounting holes in the bed, or make new ones:
First drill pilot holes with a 1/8 bit in the mill for accurate pilot hole locations.
Then a 13/64in (5.16mm) bit on other machine/drill to prepare for tapping, (because it's harder to find a collet for)
Or you can use the R8 drill chuck to directly drill this hole on the mill.
then tapped using an M6 tap.
Training notes: - Choosing inside corner radii based on bits used.
Skills: - Mapping G-code to physical workpiece coordinates - Tool depth calibration - Re-mounting part (multi-job) - workpice holding
-You need to mill more than 1 side (having a custom mount allows flipping and matching the alignment)
-Less than 2 parallel faces of your finished part are stock
Setup:
Always ensure the Allen Key is out of the top screw after tightening spindle!!!
Inserting the collet: NA
Bits:
Types: Arbour/Shell mill? Chamfer/bevel Ball mill End mill
R8 collet > 1/8 bit - examples: V bits 20deg, gold cordcob endmills, R8 collet > 1/4 bit - examples: yellow ball nose R8 collet > 1/2 bit - examples: endmills R8 collet > 5/8 bit - examples: endmills
Aluminum: WD40 Stainless-Steel: Anchorlube Metalworking Compound
Materials:
Jaxon: Machine characteristics:
Max build size: Y: 85mm can increase to 130mm, see note below. X: 350mm Z: 250mm (distance from chuck face to vice top)
2026 Mar 22 Rigidity + Backlash tests showed that error is less than 0.1mm, maybe 0.05mm in both the X and Y axes.
Y axis increase plan: Move the Vice mount point backwards one slot to middle slot. Would also need to re-adjust the Y home position, since it likely won't reach it anymore.
G-Code:
General tips: -Work from the inside out, because the outer material is what typically touches the vice, and also the perimeter is usually more volumeous than the inner parts, so it makes the part more rigid for longer during the job.
-Do blind pockets in steps, because the deeper any single pass, the more the bit will vibrate, and this makes the walls rough. Additionally, the final pass should be very thin for the best finish.
-When running your code in UCCNC, you click the CYCLE START button. BE CAREFUL that this actually starts from the current line! If you scrolled your file, or partially ran your code before, it will resume, not restart!!
M6 = Tool change. Usually exported b FreeCAD, but ignored for our machine. M3 sNNNN = set spindle RPM
Note that the GCode can be specified in: Absolute: G90 Relative: G91
G53 #0 = Machine Coordinates, where 0,0,0= the homing position. G54 #1 = User defined #1. G55 #2 = User defined #2 … G59 #6 = User defined #6 WARNING: when axis is homed, any error corrected will cause all workspaces to shift by that amount! DO NOT HOME the machine between operations! This is because all user-defined workspaces are relative to/nested inside Workspace #0. However, they are not all nested within each other consecuitively. Example: Workspace #2 is not affected by workspace #1, only Workspace #0.
There is one more offset: the “tool offset” which is nested in every workspace. It only affects Z. Note that this is not the same as “tool radius compensation”.
In UCCNC: In the “Main” window 3D view, the blue pointer represents the origin of the SELECTED workspace. The yellow is the actual toolbit location relative to the selected workspace.
Setting workspace coordinates: Do this before starting to execute CAM GCode. In the CAM software, usually it will say what workspace # you are exporting for. In UCCNC, activate the workspace you want: G54 Then, manually move the bit to the origin point you want to use. (using the “manual drive” buttons in UCCNC) Then you need to save this position into UCNC as the origin for Workspace #1. Do this by typing the command: G92 x0 y0 z0 OR you can click “ZERO ALL” blue button. The current position is now set to be the origin for Workspace #1.
A G0 is used for a “rapid move” (at the machine's native feed rate) Theory: a G0 move will not necessarily be a straight line: each axis moves independently and max-out speed independently. The controller will decide the best way to get to destination. For example, it will always move Z up first before X/Y???? And then a G1 is used for cutting (interpolated) Also, G0 uses the machine's built-in feed rates, whereas G1 uses the last feed rate specified.
For semi-manual G-Code, cheatsheet: MDI = Manual Data Input box First check: #Relative positioning: G91 #Interpolated move: G1 F1 Z1
