Ultrasonic Cleaner
Everybody loves lasers
Status WORKING as 2017-07-21
Training NO
Usage Restrictions Open to all
Owner Vancouver Hack Space
If it Breaks Turn off. Put a BROKEN sign on machine. Notify forums immediately.
Loan Status Owned by VHS
Arrival Date July 20, 2017
Location Top shelf H5
Value $350
  • Powerful 300W Ultrasonic Cleaner
  • Large 6 Liters (1.58 gallon) stainless steel (SU304) tank
  • Tank size: 12.8“ x 8.0” x 3.9“. The longest item which can fit in is 13.4”
  • 2 Color LED display. 1-30 minutes full range timer for ultrasonic cleaning
  • 5 heating temperature settings from 40 degree C (104F) to 60 degree C (140F)
Examples of things you can clean
  • PCBs
  • Precision parts (bearings, gears, valves)
  • Tools
  • Lab items (glassware)
  • Electrical parts
  • Lenses and mirrors
  • Glasses
  • Bicycle components
  • Automotive parts
Modes of cleaning
Regular
Only tap water is needed
  • Add water to the cleaning take to the level between “MIN” and “MAX” lines and above area to be cleaned
  • Put the items to be cleaned inside the basket and put the basket inside the tank
  • Set temperature if needed and wait for liquid to reach set temperature.
  • Turn the main switch on. Press TIME button to set the timer to 5-10 minutes. Press On/Off button to start cleaning.
Note. Plastic basket absorbs about 30% of ultrasonic energy. Metal will absorb 8%.
Indirect Cleaning
You may use different cleaning fluids with this method. ie.
  • Alcohol for electrical parts
  • Acetone to dissolve ink
    • Put items in separate container. Use ultrasonic waves to penetrate the container to do the cleaning.
    • Put the item inside a container. Add proper fluid to submerge item.
    • Place the container in the tank directly. Add water to a level between MIN and MAX.
    • Set temperature if needed, wait for liquid to hit set temperature
    • Press TIME button to set the timer to 10 minutes. Press On/Off button to start cleaning. Ultrasonic waves will penetrate the container and clean the items.
Selection of containers
  • Plastic container - These are soft and will absorb about 30% of the energy
  • Aluminum container - Absorb 20% of energy
  • Stainless steel container - Absorb 8% of energy
Precautions
  • ALWAYS use a to suspend your item to be cleaned above the stainless steel bottom. Failure to do so will damage the basin
  • DO NOT operate the device before filling the tank. Doing so may damage the machine.
  • ONLY fill the machine between the MIN and MAX markings on the basin.
  • Do not use abrasive cleaning solution or strong corrosive chemicals.
  • If cleaning multiple parts simultaneously, keep parts away from each other. If they touch, they may damage each other.
Clean-up and Storage
  • Rinse, drain, and wipe the reservoir dry.
  • Store the ultrasonic cleaner on a shelf in the paint and mess room.
wiki/tools/ultrasonic_cleaner.txt · Last modified: 2021/03/27 10:07
