Sherline 5000 CNC mill
Status Sort of works (contact Jarrett, Richard, or Luke B for details)
Hackable Sort of (please keep usable as a CNC machine)
If it Breaks Put a “broken” sign on machine, post to Talk with details.
Loan Status Donated to VHS by John Craver
Arrival Date June 2010
Location Workshop
Information:
Forum thread: https://talk.vanhack.ca/t/vhs-group-project-sherline-cnc-mill/2588
For regular mill's operation:
login: vhs
password: vhs
For administrative tasks only the root password is hackspace.
  • Safety Glasses
  • Clamping devices (apply https://talk.vanhack.ca/t/vhs-group-project-sherline-cnc-mill/2588 liberally; better to have more clamps at moderate pressure than few at great pressure, to avoid damaging the T-slot)
  • an experienced machine operator (if this is not you, you must get someone to help you!)
  • long hair must be tied back
  • Face Shield
  • Hearing Protection (The CNC machine isn't very loud, and you will be able to determine how well a particular job is running based on how the machine sounds)
  • Gloves, loose clothing (NEVER near rotating machinery!)
  • Unclamped Material (can be thrown off the machine!)
Startup
  • With the power disconnected, clear all non essential material from the CNC working area.
  • Connect power.
  • Open the front door of the CNC cabinet to access the keyboard, mouse, axis power and PC power.
  • Make sure axis power is set to off.
  • Turn on the PC.
  • login: vhs
  • password: vhs
  • Start LinxCNC
  • Make sure the big red Emergency stop button is off (pulled out).
  • Enable the axis power.
  • verify that there are no loose wires and the machine appears to be in good working order
  • handle any warning messages that LinuxCNC reports.
  • Proceed with prep and cut.
TODO: FINISH THIS
Shut down
  • Quit LinuxCNC
  • Disable axis power
  • Logout of linux with the “shutdown” option
  • Wait for all systems to turn off
  • Disconnect CNC
  • Stow keyboard, mouse, and extension cord in CNC
  • Remove your tool(s) from the chuck.
  • Clean up the cutting leftovers. The next user thanks you!
PCB Milling
Notes for later:
wiki/tools/sherline_cnc_mill.txt · Last modified: 2026/06/24 21:37
