Redsail CM1080 Laser Cutter
Everybody loves lasers
Status OPERATIONAL as of April 9, 2024
Training YES (see below)
Owner Vancouver Hack Space
If it Breaks Turn off. Put a BROKEN sign on machine. Notify forums and Laser Cutter Committee immediately.
Loan Status Owned by VHS
Arrival Date March 30, 2012
Location Back of VHS
Value $3500 + ~$1000 to get it here and set up
All members using the laser cutter must have read and understand the Laser Cutter Operation Manual and completed VHS Laser Cutter Training.
The dangers associated with the laser cutter include beam exposure, fire, electrocution, and exposure to dangerous fumes.
While it is important to follow all rules and guidelines, the following are critical:
  1. Wear the Laser safety glasses at all times.
  2. Operator must remain within 1m of the machine and monitor cutting at all times when the machine is in operation.
  3. Only burn Approved Materials. (See Laser Cutter Approved Materials List)
Failure to follow these rules may result in immediate loss of Laser Cutter priviledges.
Anyone who wishes to use the laser cutter must be both a VHS member, and have completed VHS Laser Cutter Training. Class dates are announced on the VHS forum) and are on our calendar
  • Bed size: 1020mm x 820mm
    • Total work area size: 1000mm x 800mm
    • Honeycomb grid (small): 630mm x 470mm x 20mm high
    • Honeycomb grid (large): 900mm x 600mm x 20mm high
  • Type: CO2
  • Power: 80W
  • Controller: Ruida 6445 (replacement installed in 2023)
  • Power supply: LSR-JN80WCO2-2V
    • Input: AC 220V
    • Power: 80Watt, 100Watt peak
    • Triggering Voltage: 28KV
    • Operating Voltage: 22KV
    • Current: 32mA max
    • 3pin terminal pinout: G, AC, AC
    • 6pin terminal pinout: H, L, WP, G, IN, 5V
  • 3-Phase Stepper Motor Drivers: Cloudray 3DM580S or Moons 3SR8H
    • Note: Different driver models have different pinouts even though the connectors are the same. DO NOT swap connectors without changing the wire order.
    • Input: DC 40V
    • Motor current: 4A
    • Steps/rev: 5000
    • Idle current: half
    • Power-on self test: off
Usage and Maintenance
Further Information
Tutorials
Possible upgrades
wiki/tools/redsail_cm1080_laser_cutter.1734503089.txt.gz · Last modified: 2024/12/17 22:24
