'Jaxen' - CNC Milling Machine
It is currently being prepared for wider member use.
Status Operational.
  • Runs UCCNC
  • Includes R8 tooling
Jul 4, 202X AndroidLX Significant modifications performed. Machine confirmed to run UCCNC, noted as “not particularly user-friendly.”
Mill and original stand as donated by Chris: Jaxen CNC Milling Machine
Pic of Jaxen about 2026 Jan: Jaxen CNC Milling Machine
CNC mill controller setup
NDR-480-48
1. Power Supplies
Hookup:
2. Motor Drivers
  • Wiring:
 Motor Drivers
HSS57 Hybrid Servo Driver
HSS57 driver datasheet
Device Identification
  • Model: HSS57
  • Voltage Range: 24–50 VDC
Connections
Motor (4 terminals)
  • A+, A–
  • B+, B–
Encoder (6 terminals)
  • VCC
  • EGND
  • EA+, EA–
  • EB+, EB–
  • ENA+, ENA– : Enable input
Pulses/Rev SW3 SW4 SW5 SW6
Default on on on on
10000 off on off off
** Key Features **
  • Alarm output via ALM pins
Photos of Z Servo Driver
MA860H driver manual (PDF)
  • Model: MA860H
Connections
Signal Inputs
  • ENA+ / ENA– : Enable input
Motor Outputs
  • A+, A– : Motor phase A
  • B+, B– : Motor phase B
Power Supply
Key Features
3. Ethernet Motion Controller
  • Ports:
 Breakout I/O Board
5. Motors
X and Y axis Motors
** XY Motor Identification**
  • Model: 57HSE2N-D25
** XY Motor Leads**
  • A+ = Red
  • A- = Green
  • B+ = Yellow
  • B- = Blue
** XY Encoder Leads**
  • EA+ = Black
  • EA- = Blue
  • EB+ = Yellow
  • EB- = Green
Typical Wiring Diagram
Attribute Value (typical)
Frame Size NEMA 23 (57 mm)
Resistance ~0.5–0.8 Ω/phase
Inductance ~2.5–4.0 mH
Function in Your CNC (Jaxen)
Z Axis Motor not documented
Limit Switch Configuration
Physical Layout
Function in UCCNC
Feature Description
8. Spindle Feedback Encoder
  • Model: E38S6G5-600Z
  • Body size: 38 mm diameter
  • Supply voltage: 5–24 VDC
Function
    • Rigid tapping
    • Thread cutting
    • Accurate spindle homing
References
9. Spindle Control Board
10. E-Stop
tbd
11. Tool Offset Sensor
 Tool Offset Sensor Gauge
Parameter Specification
Model MY20-20-2
Repeatability ±0.001 mm
12. PC & UCCNC Software
Signal Flow Summary
wiki/tools/jaxen_cnc_mill.1785222044.txt.gz · Last modified: 2026/07/28 00:00
