Grizzly G0463 Mill "Gage"
Due to similarity to Jaxen, and the fact that it was not operational (ever?), it was disposed and sold. The CNC mill Jaxen is now in it's place! Many parts and equipment for Gage is compatible with Jaxen. Learn more about Jaxen here:
Status Disposed
Owner Richard Sim; sold as scrap with proceeds to owner.
If it Breaks Let Richard S. know, put up an Out of Order sign.
Location Disposed
Retirement Date 2026 July
Champion N/A
wiki/tools/grizzly_x3_4-axis_cnc_mill.1786166128.txt.gz · Last modified: 2026/08/07 22:15
