Information
  • Quantity = 2
  • user certification required = Must be or be with an experienced operator
  • model = Bosch 1375A 4-1/2“ Small Angle Grinder
  • serial # =
  • arrived = July 2014
  • does it work? = Works
  • if it breaks = Put a "broken" sign on machine, contact John.
  • contact = John Craver
  • where = workshop
  • replacement value (each) = $80
Mandatory:
  • Face Shield AND Safety Glasses
  • Hearing Protection
  • Leather Work Boots
  • Fire Extinguisher
  • A clean work area (clutter makes it hard to search for embers)
  • Clamps or Bench Vise
Optional:
  • Heavy leather welding gloves
  • Leather apron
  • Clothes made of synthetic materials (can catch on fire)
  • Any gloves other than heavy leather welding gloves (can get caught
  • Jewellery, Long Hair (tie back), and loose fitting clothing.
  • Aluminum (Never grind aluminum, it can cause the grinding wheel to explode)
Description:
To avoid accidents, the following operational safety rules must be observed by everyone using the Vancouver Hack Space angle grinder. Failure to follow the safety rules may result in a loss of shop privileges.
  • Do not use the angle grinder when there are others in the space, unless they are paying attention to your work and they are also wearing the required personal protective equipment!
  • Safety glasses and a face shield MUST be worn. Hearing protection MUST be worn. Always have a fire extinguisher or bucket of water nearby when grinding.
  • Remove loose fitting clothing, jewelry, and tie back long hair.
  • Give the work your undivided attention.
  • Always search thoroughly after grinding for any sparks which may cause flammable material to ignite.
  • Approach your work at VHS and with the cordless drill with a safe attitude!
  • Never use any grinding accessory larger than 4.5 inches in diameter!
  • Always check that the maximum safe operating speed of the grinding accessory is greater than that of the grinder!
  • Never remove guards!
  • Never grind aluminum!
wiki/tools/bosch_4.5_angle_grinder.txt · Last modified: 2015/12/12 06:31
