Spindle Sander
The oscillating edge belt/spindle sander has 2 machines in 1 that combines edge belt and spindle sanding in a single high performance tool. It operates with rotary and oscillating motion to achieve burn-free finishes on edges, contours, faces and inside and outside curves with a tool-free conversion from belt to spindle that easily makes changes and completes multiple jobs.
The spindle sander and belt/disk sander both live in the sander cart. If you see the belt/disk sander, remove the lag bolt, flip the table, and re-insert the lag bolt to switch to the spindle sander.
Model / Serial Ridgid EB4424 Oscillating Edge Belt/Spindle Sander
Status (Operational) as of 2020-11-30
Training Read operating manual
Hackable No
Usage Restrictions (Anyone, Members Only, Keyholders Only, Whitelist)
Owner VHS (group buy)
If it Breaks tag it as out of order and post on #woodworking Slack channel or forum
Loan Status Owned by VHS
Arrival Date 2020-11-30
Location Woodshop (sander cart)
Value $200 CAD
Wiki entry created Nov 20, 2013 John C
wiki/tools/bernie_the_spindle_sander.txt · Last modified: 2026/02/22 15:05
