Button Maker
Status Operational as of April 2019
Training Recommended so you don't waste materials
If it Breaks You'd have to make a real effort to break this. Don't drop it.
Loan Status Owned
Arrival Date Date
Location Underneath the crafting table, side closest to couches
Notes about the button maker:
* It makes 1 1/2“ buttons
  • There is a cutter (“Tecre Graphic Punch”) to cut out paper circles for buttons. It should be with the button maker. It's made of metal and is pretty heavy duty, about 5“ square base, with a little handle to pull down and punch the circles out.
Template
Template for designing your button button_template_markup.pdf
Supplies
Button maker and button supplies are located under the craft table, near the couches. Locally Blim and Six Cent Press have parts.
wiki/tools/badge_a_minit_button_maker.txt · Last modified: 2026/04/07 19:57
