Air Compressor
Make & Model Campbell Hausfeld VT627505AJ
Serial Number L12/18/07-00082
User Manual vt6275_manual.pdf
Status Operational as of 2021-04-21
Training RTFM
If it Breaks Post on Talk, tape an Out of Order sign onto it
Arrival Date Date
Location Woodshop soundproof closet
Oil type: SAE30 Air Compressor Oil, or 10W30 Full Synthetic motor oil
Specs: 60 Gallon 135 PSI Max. 3.2 HP Motor 240V 15A 60Hz 1ph 11.5 SCFM @ 40PSI 10.2 SCFM @ 90PSI
Motor: Model: Emerson T63XWBSS1486 Definite Purpose Compressor Motor FLA: 15.0 RPM: 3450 Frame Size: 56 Insulation Type: T Duty: Continuous Locked Rotor Amps: 93
Wiki entry created 2021-04-21 John C.
Oil changed 2021-04-21 John C.
wiki/tools/air_compressor.txt · Last modified: 2021/04/29 20:06
