Laser Filtration System
It is well understood that depending on the material being “lased” that the fumes from a laser cutter can be detrimental to human health, either through the release of particulates, or volatile organic compounds (VOCs) (reference: Download PDF). In particular, wood creates a significant amount of small particulate matter, while most plastics create various VOCs that must be removed from the exhaust stream before it is ducted either inside or outside the space.
Many commercial systems exist in order to address these concerns, and in general follow the same design principles:
- Utilize sufficient air flow to clear the space, while keeping the filter and laser under negative pressure.
- Have a staged filter setup to remove various substances consisting of:
- Pre-filtration - remove large particles using a larger bag filter, washable medium, or cheap pre-filter.
- Small Particle Filtration - HEPA filters or equivalent can be used to remove the majority of smaller particles generated by the laser/material.
- VOC Removal - Although various methods for VOC removal exist, the most common is utilizing an activated carbon bed to remove any final VOCs
- Post Filter (Optional) - If concerns regarding the expulsion of carbon dust from the bed exist, such as a re circulation application,
- Use of sensors/monitoring to determine service intervals/efficacy.
VHS has a custom build design which incorporates all of these elements, and is flexible in order to pursue upgrades in the future as necessary.
Air Flow Requirements
For an 80W CO2 laser such as that of VHS, the suggested minimum flow rate is 250cfm. In order to meet these requirements, a target setpoint of 350cfm was used. To meet this spec, two axial fans original designed for hydroponic applications were investigated. The fan curves are below:
Given the 6' ducting, and required filters, the major and minor Dp's were calculated and compared to the available fan curves. This determined that the optimum setup was a single M6 fan with minimal other backpressure as seen below:
Filter Setup
The VHS laser filter system is designed to use standard 20“ x 25” furnace filters in two identical parallel stacks (see photo below). Each stack comprises, from bottom to top:
- Bottom plenum (i.e., empty space); coarse particulates get deposited here
- MERV 6 / MPR300 Pre-filter (x3 layers)
- MERV8 / MPR 600 Furnace filters (one 2“ layer or two 1” layers)
- MERV11 / MPR 1000 Furnace filters (one 2“ layer or two 1” layers)
- MERV13 / MPR 1900 Furnace filters (one 2“ layer or two 1” layers)
- Jacobi Ecosorb GXB or equivalent granular activated carbon, 4mm or 5 mm particle size (x3 layers)
This system is designed to: a) reduce particulate entrapment in the fine particulate phase, b) ensure removal of particulate matter which is roughly similar to tobacco smoke as per literature on laser exhaust, and c) have sufficient residence time of the air in the carbon bed, while not increasing the overall dP of the filter system.
According to literature from the EPA (Download PDF) it is suggested to use a minimum bed depth of 3“, along with face velocities of between 50-100 fpm to reduce streaming and breakthrough, while providing sufficient residence time. It should be noted that in this setup, the number of trays and flow area has been maximized in order to lower dP, and increase residence time. At the specified 350 cfm, and the 1/2 filter box area currently in use, the residence time in the current design is approximately 0.3s.
Filter Maintenance
Basic Filter Maintenance Note: filtered material is a potential health hazard. Wear PPE while working on the filter, at minimum a dust mask and gloves should be worn, and a vacuum with a suitable filter attached. Most filtered material is water soluble, and a damp rag can be used to wash dirty surfaces.
In order to maintain the filter stack, complete the following every two weeks:
Deposit area Vacuum thoroughly and wipe down with water and a damp rag. Washable Pre-Filter Hand wash in the large sink, and then shake excess water off before hanging to dry. When reinstalling the prefilters, care should be taken to ensure they are fully supported and sitting flat on the filter box frame as they tend to get snagged during installation. Furnace Filters Each filter should be vacuumed and inspected during each maintenance interval. While there are no specific change intervals, once a filter becomes clogged with debris it should be replaced. Current experience is that the filter media shouldn’t need to be replaced any more frequently than once every 3-6 months, but this will be highly dependent on usage. In each set of filters, it is recommended to replace the lower filter first, and add the new filter to the top of the stack. Repeat for each bank of MERV 8, 11 & 13 filters. Activated carbon trays (top three) are not a part of this basic maintenance procedure and can be left alone.
Important Things to Note:
The air in the filter stack moves from bottom to top. All filter elements have an arrow indicating the direction of airflow. When installed correctly, the text on the filter elements will be upside down, as seen in the picture above. Always rely on the direction of the arrow. There are three different types of filter elements, each with different characteristics. It is imperative that they are installed in the correct order. In the current configuration, only L2 filters (the dark blue filters without a paper frame) are washable. If a filter element is replaced, please label it with a date.
Testing
The filter has been tested and will be continuously monitored by the control system to ensure:
- Min 300 cfm across the fan
- Max dP across the bed
- No VOC breakthrough
- No particulate breakthrough
At any time if there is a concern over filter operation or maintenance, please contact any member of the LCC via #laser on Slack.
