VHS Laser Cutter Approved Materials
Only the following materials may be cut or engraved on the VHS Laser Cutter. If the material you wish to cut is not listed, please see: How do I get a new material approved?
Settings are provided here as a starting point. Always do test cuts to find optimal settings.
Papers
Material Mode Speed Power Corner Power Passes Notes
Card Stock Etch 35 10 10 1
Card Stock Cut 35 35 25 1
Heavy paper Cut 200 20 20 1 Worked barely; long straight cuts needed multiple passes, and a few corners were missed. Use lower speed
Picture Matting Cut 40 50 40 1
Corrugated Cardboard
Woods
Please avoid the use of woods with any water, sap, or a high proportion of glue. They quickly clog the filtration system and leave substantial residue on the laser cutter.
Plywood 1/4“ Birch Cut 40 50 45 2 From Home Depot ~$50 for 8'x4'
Plywood 1/8” Birch Cut 24 55 55 1 From Windsor Plywood ~$17 for 5'x5'
Plywood 1/8“ Maple Cut 24 55 55 1
Plywood 1/8” Birch Etch 80 28 28 1 Deep etching, excellent for countersinking screw holes
Plywood 4.2mm FSC Virola Cut 40 50 45 2 From Home Depot ~$20 for 8'x4' SKU 1000-125618 (Tom)
Plywood 1/4“ Flooring underlay Cut 12 60 60 1 From Home Depot ~$9 for 4'x4'
Plastics
Many plastics are banned because of fumes. Banned plastics include Lexan/Polycarbonate/Makrolon, ABS, PVC, Vinyl, Neoprene/Polychloroprene and Delrin. Please see the banned materials list below. Please don't put banned plastics in the Laser Cutter off cuts bin. The acceptable plastics are:
Acrylic - 1/4” (6mm) Cut 20 40 40 1
Acrylic - 1/16“ (1.5mm) Cut 25 30 30 1
Acrylic - 3/16” (4.5mm) Cut 20 35 35 1
Acrylic - 1/8“ (3mm) Cut 25 35 35 1
Polypropylene (0.75mm) Cut 30 50 45 1 From Yoko-yaya, ideal for painting stencils (John)
EVA Foam (very thin, < 4mm) Cut 1 Michaels
EVA Foam (thin, ~1/4”) Cut 1 Bought online, could not find locally
EVA Foam (thick, 1/2“ floor mats) Cut 30 50 50 1 Canadian Tire, Home Depot, etc.
PET/PETG (e.g. Mylar™ ) Cut 1
PET/PETG (1/16”) Cut 30 45 1 From Associated Plastics
Kapton Polyimide Film MSDS
Styrene - 2mm Cut 1 2mm white styrene sheet from hobby stores
Kaizen Foam Cut 1
Fabric
Leather (Vegetable Tanned) Cut 1
Felt Cut 100 25 1
Other
Application Tape Small amounts used for masking
Painters Tape Small amounts used for masking
Laserbond100 Marking Spray Aerosol propellants are nasty - ensure the coating has fully dried before lasering
Cermark 6000 Marking Spray Aerosol propellants are nasty - ensure the coating has fully dried before lasering
Rustoleum Painters Touch Spray Paint Aerosol propellants are nasty - ensure the coating has fully dried before lasering
MSDS
Krylon Dual Superbond Paint + Primer Gloss Black Aerosol propellants are nasty - ensure the coating has fully dried before lasering
MSDS
Etch Only
Anodized Aluminum Vector Etch 1
Banned Materials
The following is a non-exhaustive list of materials that must not be cut or engraved on the VHS Laser Cutter.
Material Reason
Wet or 'raw' wood Clogs up filter BADLY
MDF, HDF, and reconstructed wood Clogs up filter BADLY
Coroplast Clogs up filter BADLY
Lexan/Polycarbonate/Makrolon Dense black smoke and toxic fumes - bisphenol a (BPA), phenol, and more
ABS Dense black smoke and toxic fumes - cyanide and styrene gases
PVC, Vinyl Toxic and corrosive fumes - chlorine gas
Neoprene (polychloroprene) Toxic and corrosive fumes - chlorine gas
Foam core Dense black smoke and toxic fumes - styrene gas (carcinogenic, toxic to the nervous system and upper respiratory tract; classified as “very toxic”)
Delrin Toxic fumes - formaldehyde
Moleskine notebook covers Toxic fumes - chlorine - See Polymer burnination link at bottom
Carbon Fiber Hazardous dust
Fiberglass Hazardous dust
Printed Circuit board Hazardous dust
Chrome Tanned Leather Toxic/hazardous fumes
Provisionally Approved
The following materials have been provisionally approved by the Laser Cutter Committee for testing:
Cork Cut TBD TBD TBD TBD
Cork Etch TBD TBD TBD TBD
FURTHER INFORMATION
wiki/groups/lasercutter/settings.txt · Last modified: 2026/02/12 11:18
