Grizzly G0463 Mill "Gage"
Due to similarity to Jaxen, and the fact that it was not operational (ever?), it was disposed and sold as scrap. The mill Jaxen is now in it's place! [Learn more about Jaxen here!]()
| Model | Grizzly G0463 (a Seig X3) |
| Status | Disposed |
| User certification required | YES |
| Owner | Richard Sim; sold as scrap with proceeds to owner. |
| If it Breaks | Let Richard S. know, put up an Out of Order sign. |
| Loan Status | Semi-Permanent Loan |
| Arrival Date | November 12th 2012 |
| Location | Disposed |
| Retirement Date | 2026 July |
| Champion | N/A |
| Note | Date | Who |
| Moved to new workshop location and re-setup | January 14, 2017 | Luke B |
| Wiki entry updated | Aug 8, 2014 | Richard Sim |
| Ballscrew repair in-progress | Aug 3, 2014 | Richard Sim |
