Grizzly G0463 Mill "Gage"
Due to similarity to Jaxen, and the fact that it was not operational (ever?), it was disposed and sold as scrap. The mill Jaxen is now in it's place! [Learn more about Jaxen here!]()
Status Disposed
Owner Richard Sim; sold as scrap with proceeds to owner.
If it Breaks Let Richard S. know, put up an Out of Order sign.
Location Disposed
Champion N/A
wiki/tools/grizzly_x3_4-axis_cnc_mill.1785219437.txt.gz · Last modified: 2026/07/27 23:17
