Grizzly G0463 Mill "Gage"
| Model | Grizzly G0463 (a Seig X3) |
| Status | Disposed |
| User certification required | YES |
| Owner | Richard Sim; sold as scrap with proceeds to owner. |
| If it Breaks | Let Richard S. know, put up an Out of Order sign. |
| Loan Status | Semi-Permanent Loan |
| Arrival Date | November 12th 2012 |
| Location | Disposed |
| Champion | N/A |
Summary
Due to similarity to Jaxen, and the fact that it was not operational (ever?), it was disposed and sold as scrap. The mill Jaxen is now in it's place!
| Note | Date | Who |
| Moved to new workshop location and re-setup | January 14, 2017 | Luke B |
| Wiki entry updated | Aug 8, 2014 | Richard Sim |
| Ballscrew repair in-progress | Aug 3, 2014 | Richard Sim |
